HWZ Forums
Login Register FAQ Mark Forums Read
bad habit? reduce speed before curves, but speed up once entering corner
Like Tree2Likes
Reply
LinkBack Thread Tools
Old 24-04-2012, 09:06 PM   #1
and the more I feel the car can take it, I speed up even more...
what do u think? should I kick this habit
alamakazam_ is offline   Reply With Quote
Old 24-04-2012, 09:09 PM   #2
touchme's Avatar
Normal way of throttling around turns what .
touchme is offline   Reply With Quote
Old 24-04-2012, 09:12 PM   #3
Senior Moderator
Yes you should kick this habit.
__________________
[color=blue][SIZE="1"]It is better to keep quiet and be thought a fool, than to speak and remove all doubt.[/SIZE][/color]
Dragon is offline   Reply With Quote
Old 24-04-2012, 09:12 PM   #4
compro_1975's Avatar
please maintain ur speed.... u are creating a jam behind....
__________________
[SIZE=1]Go http://imageshack.us/ N Ppost Yr Pic NPNT OK[/SIZE]
I AM FROM THE 30.1%, EMPOWERED TO COMPLAIN
compro_1975 is offline   Reply With Quote
Old 24-04-2012, 09:18 PM   #5
ceecookie's Avatar
Dont increase speed or use the brake when entering corners. Both increase the risk of oversteer.
Slow down before entering the bend, and floor it after exiting(but not in the midst of) the bend
There are four major active causes of oversteer, but what you're likely to encounter depends on the car being driven (for more information on this please skip to the next section). Causes include:
  1. Entering the corner too fast
  2. Accelerating into the corner, too early or too aggressively
  3. Braking into the corner or mid corner
  4. Lifting off the throttle mid-corner.
Source
__________________
Tinky Winky is so far into the closet, he can see Narnia!
ceecookie is offline   Reply With Quote
Old 24-04-2012, 10:33 PM   #6
q w e r t ii's Avatar
reduce speed before bends, and start throttling once u reach the apex.
__________________
You're gonna catch a cold, from the ice inside your soul
q w e r t ii is online now   Reply With Quote
Old 24-04-2012, 10:43 PM   #7
idioot's Avatar
hahah actually. i think this habit is good. it curbs understeer and guides the car nicely through the driving line of the corner. maintain good speed and also stability through the corner.
best part is, the feeling is dam shiok as you step on the gas once u enter the corner and smoothly take the shortest distance across the corner and exit on the outer lane. upps
idioot is offline   Reply With Quote
Old 24-04-2012, 10:55 PM   #8
tekster's Avatar
Guess I'm not the only one
tekster is offline   Reply With Quote
Old 24-04-2012, 11:46 PM   #9
ladiesman217's Avatar
Then try to correct your bad habit by increasing speed before curves, and speed up once entering corner.
Works for me
ladiesman217 is offline   Reply With Quote
Old 25-04-2012, 01:28 AM   #10
darkmatt's Avatar
wrong technique la.
1) maintain speed before entering corner,
2) tap brakes before apex then turn,
3) once clear apex drop gear and floor
__________________
http://valid.canardpc.com/show_oc.php?id=2568156
darkmatt is offline   Reply With Quote
Old 25-04-2012, 06:58 AM   #11
lousydk's Avatar
The replies is getting more and more imba
Become racing techniques and fastest way to get round a corner
lousydk is online now   Reply With Quote
Old 25-04-2012, 09:13 AM   #12
Senior Moderator
This is correct.
But drivers who cannot judge or see the apex and racing line will end up wrapping barriers and trees.
__________________
Old 25-04-2012, 10:21 AM   #13
weng's Avatar
drive safely. think of your loved ones.
__________________
[Fav]
- XBA-N3, DN-2000, ES5
- Clear, Elear, HD/600/650/660S/800S
weng is offline   Reply With Quote
Old 25-04-2012, 11:23 AM   #14
takeshi_umuro's Avatar
well easier said than done on streets if you consider other road users safety in mind. Those techniques are more applicable on track.
However on streets at lower speed it's better to adopt a slow in fast out methodology in general imo.
Feel like a racer and do it on streets, best case scenario, you escape unscathed, not so good case, your car and yourself wrapped around trees (we know which kind of drivers/cars do that often, and more likely than not, it's drivers not knowing the limits) and worst case, you bring along other road users.
So like what Weng say: Drive safely
and if you would like to race, please go track.
seizure_ and daniel_91 like this.
__________________
VCP3/4/5, VCAP4, RHCE, NCDA, NCIE, MCSE 2003
takeshi_umuro is offline   Reply With Quote
Old 25-04-2012, 12:02 PM   #15
Stallone's Avatar
I lift off the throttle when near bend.. n depending on the turning circle, i will reduce/increase speed accordingly when in bend..
upon seeing a straight road ahead, lup throttle n exit bend..
SG roads no much bends la.. There's a diff between a turn n a bend.. a turn is something like the filter-left turn.. a bend is something like those roads entering a highway from an opposite direction
__________________
It ain't Over Till it's Over
Stallone is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
