HWZ Forums
Login Register FAQ Mark Forums Read
Power steering uses car battery?
Share This Page
HardwareZone.com on Facebook
Reply
LinkBack Thread Tools
Old 22-07-2012, 01:28 AM   #1
Shingoz's Avatar
Happened to me whenever i started my car today...the power steering dont work and i had to restart my car 1-2 times....
Even when power steering resume, during the first 5 min the ' low battery' warning light came on...but thereafter it went off... and the drive became smooth (no warning light nor lost of power steering).
Is this a case of low batt? Does low batt affect power steering? Sigh, just changed the batteru last June (from Hankook).
__________________
When you cant change the environment, change your thinking.
Shingoz is offline   Reply With Quote
Old 22-07-2012, 01:31 AM   #2
Shingoz's Avatar
seems like its a no? Could A Faulty Battery Effect My Power Steering In My Car? - Blurtit
__________________
Old 22-07-2012, 09:39 AM   #3
better have it checked out by the workshop.
Power steering systems comes in either hydraulic or electric, some with a mechanical connection to the wheel so that you can still steer the car manually even if the powernsteering fails.
__________________
[SIZE=1][/SIZE]
bolts is offline   Reply With Quote
Old 22-07-2012, 10:10 AM   #4
FeiFongWong's Avatar
Power steering uses hydraulic but the car needs to power up in order for the hydraulic pump to work.
The power steering should work once ur engine is running, if nt, there might be some fault with your hydraulic fliud or pump.
FeiFongWong is offline   Reply With Quote
Old 22-07-2012, 10:33 AM   #5
Shingoz's Avatar
Thks guys. Does anyone know of a place to change car batt in e west? Need to clear the low batt warning and see how it goes..
Old 22-07-2012, 10:37 AM   #6
U can try Stamford Tyres at Lok Yang or Autobacs at bukit batok, cos its Sunday today, not many place open.
Old 22-07-2012, 10:40 AM   #7
Shingoz's Avatar
Thks! Autobacs will they 'chop carrot'?
Old 22-07-2012, 10:46 AM   #8
Reasonable price means you have to avoid Stamford and Autobacs.
They are more expensive than smaller workshops. Battery replacement can be done at Eng Wah - Tyre shop but they are confirmed close on Sunday.
Try Soh Brothers at Ang Mo Kio, call Frankie at 64549071 to see if open today.
__________________
[SIZE=1][/SIZE]
Old 22-07-2012, 11:12 AM   #9
Shingoz's Avatar
Thanks guys! Nothing in the west? Got another contact too but is at seng kang
Old 22-07-2012, 12:16 PM   #10
Shingoz's Avatar
Sigh I think it's the battery...car can't even start now....but there's no cranking at all. Is it normal?
Old 22-07-2012, 12:39 PM   #11
tckrto's Avatar
Jump start lor. But sometimes your alternator also gone together with battery. Then more money liao
tckrto is offline   Reply With Quote
Old 22-07-2012, 12:46 PM   #12
GP also electric steering, needs power to turn.
Go have your batt changed. Arrow tyres should be opened on sundays as well, remember print voucher from their sgcarmart ad for discount.
lattesurf is offline   Reply With Quote
Old 22-07-2012, 02:21 PM   #13
ZhuTou!'s Avatar
Totally cant start now?
U can call kb lee to go onsite change for u
Price ok ok la
Juz that u save time on towing
ZhuTou! is online now   Reply With Quote
Old 22-07-2012, 03:57 PM   #14
Shingoz's Avatar
Price ok ok la
Thanks guys! Just changed batt...managed to start already. But there's a new warning light for injection system...looks like I got to visit the ws Tmr....
Old 22-07-2012, 08:02 PM   #15
danguard's Avatar
I go to jazz forums find a contact for car battery on site also price not bad I save on towing also
danguard is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
