HWZ Forums
Login Register FAQ Mark Forums Read
Vios Fuel Tank
Like Tree1Likes
Reply
LinkBack Thread Tools
Old 12-06-2012, 10:31 AM   #1
croc1977's Avatar
Vios Fuel Tank
what is the size?
i tot 42L but i manage to top up to 44L
croc1977 is offline   Reply With Quote
Old 12-06-2012, 10:32 AM   #2
Forever_Yours's Avatar
its 42l. how u top up to 44l?
Forever_Yours is offline   Reply With Quote
Old 12-06-2012, 10:34 AM   #3
emitchan's Avatar
what is the size?
u squeeze?
IIIUSION likes this.
emitchan is offline   Reply With Quote
Old 12-06-2012, 11:26 AM   #4
gohsj89's Avatar
previous generation is 45L
current generation is 42L
gohsj89 is offline   Reply With Quote
Old 12-06-2012, 02:08 PM   #5
NovJoe's Avatar
I remember it is up to 45L. I usually fill up to the brim and if left one non blinking bar and it will be around 40L. The engine to the tank will have around 3 to 5L as reserved.
NovJoe is offline   Reply With Quote
Old 12-06-2012, 02:38 PM   #6
Moderator
tmfwy's Avatar
u squeeze?
I thought u must "hump" the car. How to squeeze?
tmfwy is offline   Reply With Quote
Old 12-06-2012, 03:47 PM   #7
weng's Avatar
maybe one end he topping up, the other end leaking
__________________
WTS: EX600, UE 600, UE 700, V80 TrueBlood, Klipsch X10, XBA 30, SE215 Blue, IE80, Toxic SP.
PM me.
weng is offline   Reply With Quote
Old 12-06-2012, 05:36 PM   #8
bendi85's Avatar
Mine is 45L but can pump 46L into it.
bendi85 is offline   Reply With Quote
Old 12-06-2012, 07:09 PM   #9
Senior Moderator
Squeeze the petrol pump, one drop one drop squeeze.
__________________
It is better to keep quiet and be thought a fool, than to speak and remove all doubt.
Dragon is offline   Reply With Quote
Old 12-06-2012, 07:27 PM   #10
emitchan's Avatar
one of the esso inside jb will actually help you to hump the car one... lol
Old 12-06-2012, 08:43 PM   #11
whaleshark87's Avatar
Theres always a reserve tank. Else when your tank empty how to go additional miles
whaleshark87 is offline   Reply With Quote
Old 12-06-2012, 09:37 PM   #12
i think the rated capacity is the recommendation
anything over might affect the fuel tank sensor
runeruin is offline   Reply With Quote
Old 12-06-2012, 10:35 PM   #13
NovJoe's Avatar
LOL... I admit that I'm one of those culprits.
Old 12-06-2012, 11:29 PM   #14
Senior Moderator
Don't worry. I've seen lots of folks done it.
__________________
Old 13-06-2012, 12:09 PM   #15
croc1977's Avatar
hit...42++ ...just mannual squeeze..
then 44 l i just stop...worried overflow
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
