HWZ Forums
Login Register FAQ Mark Forums Read
[Help] Problem detecting usb mouse on boot - Razer Naga!
Reply
LinkBack Thread Tools
Old 17-11-2009, 01:52 AM   #1
alvino77's Avatar
anyone got this problem? I've problem detecting my razer naga, upon booting, always have to plug it out and in again to gt Win7 detecting it, never had any problem with my diamondback 3G, krait etc.
Anyone with solutions? I have reinstall the driver a lot of times already! Is it a mouse problem?
TIA
alvino77 is offline   Reply With Quote
Old 17-11-2009, 02:00 AM   #2
alvino77's Avatar
oh yeah btw, i've tried other usb ports, same scenario. the razer kb got lighted, but mouse didn't. until full boot also no light.
legacy usb mouse and kb in BIOS has been enabled all along.
Old 17-11-2009, 04:22 AM   #3
AS1
AS1's Avatar
TIA
whats the hardware you are using?
sometimes need to disable boot from usb option if relevant.
__________________
You Hoot, I Huat.
http://techandcamera.blogspot.com
Processor
Motorola M68000 7.67Mhz
Mainboard
V1.2
Graphics Card
Maximum onscreen sprites 80
Memory
64 Kb RAM; 20 Kb ROM
Display
R.G.B outputs
Storage
16kb
Optical Storage
Mega CD
Casing
Version 1
PSU
230v Adapter
Audio
Yamaha YM2612 6 channel FM
OS
16bit
AS1 is offline   Reply With Quote
Old 17-11-2009, 06:59 AM   #4
Junior Moderator
lemonn's Avatar
Hey bro, same problem when i tried it... Probably a bug that requires a firmware fix.
__________________
Processor
Intel Core i7-2600K Sandy Bridge
Mainboard
Asrock Z68 Pro3-M
Graphics Card
Sapphire HD6950 2GB (Shader Unlocked)
Memory
4x4GB Crucial Ballistix Tactical Tracers Red/Green DDR3-1866 CL9
Display
Dell UltraSharp U2412M 24" IPS, Samsung 931BF 19"
Storage
Plextor M5Pro 256GB SSD, 2x WD Red 3TB, 4x Samsung F4 2TB
Optical Storage
LG UH10LS20 Blu-Ray Combo
Casing
Silverstone SG02-F White MATX
PSU
Antec Truepower New 750W
Audio
Onkyo SE-300PCIE, Creative ZiiSound T6
OS
Windows 8.1 Pro 64-Bit
lemonn is offline   Reply With Quote
Old 17-11-2009, 09:16 AM   #5
ionicle88's Avatar
cold boot issues???
firmware flash is your best choice....
does it only happen when you boot your comp up for the first time in the day? then subsequent reboots are all fine?
Processor
i5-4300U
Mainboard
Surface Pro 3
Graphics Card
Intel HD Graphics 4400
Memory
8GB
Display
12" ClearType Display (2160x1440)
Storage
256GB Samsung TLC SSD
Optical Storage
-nil-
PSU
36W Power Adapter
Audio
Stereo speakers with Dolby Audio-enhanced sound
OS
Windows 10 Pro x64
ionicle88 is offline   Reply With Quote
Old 18-11-2009, 02:12 AM   #6
alvino77's Avatar
Gigabyte EX58-UD3R, i7 920
no latest firmware for razer naga liao. its already the latest version.
cold boot issues???
everytime i reboot with a complete shutdown.
BTW, more info is, i have tried it with another PC, can work perfectly without problem, isolated the issue on the mouse. What might be wrong?
I have a ext powered USB hub, by plugging into it like an extension hub, the mouse can boot/detect normally, the problem still lies with plugging directly to the MB.
any directions?
Old 18-11-2009, 05:15 PM   #7
Might be mobo issues.
__________________
Dun trust whatever fanboy said.....zzzzzzz
longsiew is offline   Reply With Quote
Old 19-02-2010, 05:59 AM   #8
I have the same motherboard and the same mouse, currently using windows XP.
I also have the same problem.
Sometimes the mouse will give a quick flash immediately as the machine powers up, then the bios kicks in and nothing, until you unplug/replug etc.
The mouse does not power up whether from a reset, hard boot or reboot.
Gigabyte have limited driver/bios updates.
Alvino77 reckons it works ok through a usb hub, and I've read elsewhere that it works through a Usb>Ps2 connector, and that the fault is with certain mobo's that don't support certain usb boards.
Adornay is offline   Reply With Quote
Old 19-02-2010, 07:35 PM   #9
Aparrently this firmware 1.07 update works.
Just installed it, about to reboot.
http://www.razersupport.com/index.ph...emid=393&nav=0
Old 19-02-2010, 07:58 PM   #10
alvino77's Avatar
thanks for the update Adornay.
fellow Naga users, do you feel your Naga generate quite significant amount of heat even on idle. wonder whether its my copy has problem or its design flaw?
I've never encountered any mouse generating heat from it board or lasers.
Old 19-02-2010, 08:16 PM   #11
The firmware update hasn't worked for me.
Old 19-02-2010, 08:28 PM   #12
alvino77's Avatar
damn! what a shame ! Razer has been launching a lot of new mice... their quality seemed to have dropped a lot.
Old 19-02-2010, 08:57 PM   #13
Woohoo got it working.
Here is how I did it.
Downloaded the firmware updater 1.07.
Ran the program and it asks you to plug the mouse in bootloader mode (unplug, hold down left/middle/right mouse buttons and plug back in).
Your pc will then detect the mouse as a "freescale JM60 bootloader", this is the bit that was tricky.
1) I installed the freescale driver, then updated the firmware through the razer software, rebooted, this did not work.
Unplugged, plugged back in (with 3 buttons held down), machine detected freescale bootloader again asking for driver files.
2) Installed the freescale driver by pointing it to the c:\program files\razer\naga\firmware updater\bootloader\ directory, it appeared to install fine, updated the mouse, rebooted, still did not work.
3) I then unplugged the mouse, held down the 3 mouse buttons and plugged back in (machine detected freescale bootloader again asking for driver files), installed the freescale drivers, using the keyboard I went to device manager and updated the freescale bootloader driver (from c:\program files\razer\naga\firmware updater\bootloader\), installed ok.
I then unplugged the mouse, held down the 3 buttons, plugged back in and machine auto installed the freescale bootloader driver automatically this time without asking for the driver files.
Installed the firmware, rebooted, mouse is now detected by windows on boot up.
Still does not power up on boot, but at least it's working without having to swap ports.
Old 19-02-2010, 09:10 PM   #14
alvino77's Avatar
good that you get it working. lucky i got it to work on the 1st try, only did 1 x 3 simultaneous click. and update and it's fixed!
Old 19-02-2010, 09:14 PM   #15
Yeah I think our differences will be down to me using XP and you using windows 7.
In XP after 3 attempts at getting windows to install and remember the device tna, I had to go into device manager and force install the driver through driver updates.
Where as windows 7 probably bypasses this issue, by actually installing the freescale driver and remembering it.
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
