HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Like Tree38Likes
Reply
LinkBack Thread Tools
Old 08-07-2016, 09:58 AM   #46
Need help deciding on what mobo to buy.
I planned to use i5 - 6600k and GTX 1080.
Mainly use for gaming.
justin5615 is offline   Reply With Quote
Old 08-07-2016, 10:02 AM   #47
ZrE0_Cha0s's Avatar
If u want to OC get a z170 board and a 3rd party cpu cooler as well.
Next is the case u using can fit which one then buy the boards that fits.
ZrE0_Cha0s is offline   Reply With Quote
Old 08-07-2016, 04:07 PM   #48
Thanks.
In addition, what is the best monitor to go with single GTX 1080?
Old 08-07-2016, 04:21 PM   #49
ZrE0_Cha0s's Avatar
Thanks.
Anything @1440p or above resolution and 60Hz or more refresh rates.
Anyway I dun even know your budget and needs , it's very hard to give u reco.
I mean like almost any monitor that specific can be the best of its own.
Old 08-07-2016, 04:27 PM   #50
is it overkill to go for Asus pg279q or acer xb271hu?
Old 08-07-2016, 04:31 PM   #51
ZrE0_Cha0s's Avatar
Nah it's not. And if u have the budget for those that will babe good. As the GPU still can support Well with those monitor.
Old 09-07-2016, 08:59 AM   #52
Trading PC with 3 monitors
Hi guys,
My com just crashed.
Currently i have 3 x 22 inch monitor setup (16:10) and would like to retain the monitors. using
1 x DP
1 x hdmi to dvi
1 x dvi
What rig can i build with a budget of $800 sgd? inclusive of OS and possibly 16gb ram and OEM OS. How much does OS cost these days?
Thanks!
finale1 is offline   Reply With Quote
Old 09-07-2016, 09:24 AM   #53
ZrE0_Cha0s's Avatar
Hi guys,
1 x DP
1 x hdmi to dvi
1 x dvi
Thanks!
May I ask is your PC everything including OS is 800? Might be a bit hard though...are u gonna reuse ssd/HDD?
Old 09-07-2016, 09:27 AM   #54
I will get new HDD. i believe my HDD crashed.
So with $800, i will get:
CPU + MOBO (i3 is ok)
1TB HDD
16gb RAM
Casing
PSU
Graphics card (necessary? or can i use onboard?)
OEM OS
Old 09-07-2016, 09:31 AM   #55
ZrE0_Cha0s's Avatar
1TB HDD
16gb RAM
OEM OS
I still think u will need a GPU cos onboard most likely need to get h170 to have 3 display working. I mean if onboard GPU is good for you den use it.
anyway since its ur hdd spoil den change hdd can already. why build another one?
nv i forget that u need DP, which need to really need to go find, but dun think that there is a lot of onboard have dp.
Old 09-07-2016, 09:36 AM   #56
My com is 4 yearold already.
Time to change.
OK, without the OS, possible to do $800?
Old 09-07-2016, 09:53 AM   #57
ZrE0_Cha0s's Avatar
Time to change.
1TB HDD
16gb RAM
Casing
PSU
OEM OS
MSI B150M BAZOOKA + I3 6100 @306
WD 1 TB @75
KINGSTON DDR4 16GB @100
CORSAIR SPEC-01 @79
FSP 550W HEXA PLUS @68
Zotac GTX 750ti @199
Total: 827
All prices are quote from PCThemes.
Another considerations to reduce more : MSI H110 PRO VH-L + i3 6100 @288
Old 09-07-2016, 10:09 AM   #58
WD 1 TB @75
CORSAIR SPEC-01 @79
Total: 827
Thanks a lot!
Just curious, can this graphics card output to 4 x 22 inch display?
Old 09-07-2016, 10:21 AM   #59
ZrE0_Cha0s's Avatar
Thanks a lot!
Not sure about that, because, i dun usually build a gpu with more than 3 display. but u can try to source for the gpu and see if capable of doing so or not.
Old 09-07-2016, 10:24 AM   #60
Ok thanks a lot. Just one question.
There are also graphics card close to $100 that can support 3 monitors. Why do we go for this one that costs $200?
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
HardwareZone
Rewards
