HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Like Tree35Likes
Share This Page
HardwareZone.com on Facebook
Reply
LinkBack Thread Tools
Old 15-03-2017, 01:38 AM   #1321
Hi guys need advice for this build for my fren
CPU+MOBO: ASUS H110M-A/M.2 + i5 7400 ($109+$233 lazada wogi 20%)
RAM: Kingston value ram ddr4 2x4gb ($80 lazada wogi)
GPU: Zotac Gtx 1060 mini ($265 lazada wogi 20%)
PSU: Cooler Master G550M ($75 lazada wogi 20%)
SSD+Casing: Samsung Evo 850 250GB, Xigmatek Frontliner ($175 lazada wogi 20%)
Total: $937 -(shopback $12) ~$925
Is 550watts PSU enough to power this system?
Processor
i5 6500
Mainboard
Gigabyte H170-D3HP
Graphics Card
Palit GTX 580
Memory
Avexir Core Series DDR4 2400MHz 2x8GB
Storage
Casing
Deepcool Dukase V2
PSU
Seasonic M12II-620 Evo 80 Plus Bronze PSU
OS
Windows 10 Pro
predator123 is offline   Reply With Quote
Old 15-03-2017, 02:25 PM   #1322
Hi guys, need advice for building a SFF rig while reusing parts that I already have (which I will be bringing for use in Japan).
I am looking for a chassis which is around the size of the CM Elite 110/130 (or similar 'cube' form factor), and am thinking of using this with a 4K monitor.
The following are the parts I have:
CPU - 5820K
RAM - Kingston Technology HyperX FURY Black 32 GB Kit
Mobo - MSI X99A Gaming Pro Carbon
GPU - ZOTAC GTX 1070
Fan - Noctua NH-D14
Storage - Silicon Power SDD 1GB/WD RED 3TB
PSU - HX850i
Please advise which parts I could reuse and which would not fit into a chassis of that size.
Also, do I need to change the CPU/mobo and if so, any recommendations for these?
Finally, are PSU bought locally compatible with Japanese voltage, or do I have to get a new PSU in Japan?
Jargon is offline   Reply With Quote
Old 16-03-2017, 11:02 PM   #1323
CHEETT's Avatar
Hi, I am new to all this and never DIY before. Would appreciate the help and don't mind paying you for your trouble.
I will need a DIY PC that I can play GTA 5 and Counter Strike.
Was going to buy this
But many recommend me to go DIY so im here to ask and check things out.
CHEETT is offline   Reply With Quote
Old 17-03-2017, 06:48 PM   #1324
Hello Seniors!
Planning to head down to simlim this Sunday to build gaming PC with the budget of 2K. i already have the monitor, OS, keyboard and mouse. PC is just for gaming purposes and my friend have recently typed out a list of parts for me to consider
Motherboad & Processor: MSI Z170A PC MATE / i5 7600K ($569)
GPU: ASUS GTX 1070 8GB DUAL ($699)
RAM: CORSAIR VENGEANCE LPX 2400MHZ CL14 ( 8GBx2pcs ) ($199)
SSD: OCZ 120GB SATA3 TL-100 SSD 2.5" ($79)
HDD: WESTERN.D 1TB BLACK 64MB SATA3 ($112)
Power Supply: CORSAIR CX 750W 80+ BRONZE ($133)
CPU Fan: C.M HYPER D92 PWM COOLER ($69)
Casing: ????
Total: $1860
how does the above setup sounds? Thanks alot in advance!
Relekz is offline   Reply With Quote
Old 17-03-2017, 08:30 PM   #1325
Since u are only using it for gaming, do u intend to OC? Otherwise u could get a b250/h270 board with a non k 7500
GPU u could head over to carousell, lots of sellers selling their used/brand new 1070 over there, some shops even post their items over there with special prices, on average can find a 1070 over there at around 500+
WD black, u could aim for the blue or other Brands too, black a little unnecessary in my opinion, 1TB cost hovers around $50 << if u say that black is faster hence u want to go for it, might as well TOP on your SSD, over there the speed incremental is more noticeable
Cpu cooler u could get the 212x at around 49-59 depending on your seller
Hello Seniors!
Casing: ????
Total: $1860
Processor
i7 6700k 4.7Ghz (LC)
Mainboard
Z170i ASUS PRO GAMING
Graphics Card
GTX 1080 ASUS STRIX 8GB (LC)
Memory
32GB Corsair Vengence 3000Mhz (2x16GB)
Storage
Samsung 1TB 850 EVO
Casing
FRACTAL DESIGN NANO S
PSU
COOLER MASTER V1000
OS
Windows 10 OEM
joshuaho is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
