HWZ Forums
Login Register FAQ Mark Forums Read
Mount a monitor panel on the side of a casing?
Reply
LinkBack Thread Tools
Old 14-09-2012, 12:58 AM   #1
NSW
NSW's Avatar
Dear all,
I am not really into case modding but figured that my query would be best answered here.
I am contemplating a desktop build for my personal usage but would really love to mount a LCD to the side of a desktop to save space, not unlike http://img.hexus.net/v2/news/chieftec/L-type-01.jpg but it seems that this chassis has been discontinued.
Was wondering if any kind soul here can point me along in the right direction ...
Many thanks in advance!
Processor
i5-3570
Mainboard
AsRock H77M
Memory
DDR3 16gb
Display
LG IPS 236V
Storage
i520 120gb SSD + 2x2TB_RAID1
Casing
Silverstone TJ08-E
OS
Win8.1 x64
NSW is offline   Reply With Quote
Old 15-09-2012, 02:22 AM   #2
Dear all,
Can be done but most likely wont be cheap. If you want the easy way out can buy those wall mounts for monitors with VESA mounting and instead of the wall, mount it onto your side panel loh. But you must make sure your side panel can take the weight of your monitor, or you'll have to construct some weight bearing columns on your side panel.
Processor
i5-3570k
Mainboard
Asrock Z77 E4M
Graphics Card
Powercolor 7870 Myst
Memory
4x4GB Kingston ValueRam
Display
Dell U2312HM
Storage
2x Hitachi 3TB, Hitachi 2TB, Plextor m5pro 256GB
Casing
Lian Li PC-A05N
PSU
Superflower HX 450
Audio
Swans H4
OS
Windows 7 Ultimate
devilwahaha is offline   Reply With Quote
Old 15-09-2012, 10:28 AM   #3
NSW
NSW's Avatar
I am exactly thinking of the intermediary wall mount since there needs to be some degree of freedom to adjust for the ergonomics of the monitor!
Do you think the mod-shops in SLS will be able to do so?
Processor
i5-3570
Mainboard
AsRock H77M
Memory
DDR3 16gb
Display
LG IPS 236V
Storage
Casing
Silverstone TJ08-E
OS
Win8.1 x64
Old 17-09-2012, 07:17 AM   #4
Not that i know of. UVnium has closed down their physical store at SLS so thats out. What monitor(s) are you planning to mount and what casing and side panel are you using? I might be interested to do it
Processor
i5-3570k
Mainboard
Asrock Z77 E4M
Graphics Card
Memory
Display
Dell U2312HM
Storage
Casing
Lian Li PC-A05N
PSU
Superflower HX 450
Audio
Swans H4
OS
Windows 7 Ultimate
Old 20-09-2012, 05:59 PM   #5
Mycrus's Avatar
Buy vesa wall mount, screws and nuts...
Buy or borrow a drill and do yourself...
Use masking tape to mock up your drill holes in the side panel
Vesa mount get at jiaying sls
I would do this only if you are using an all steel case and a light monitor
aluminum side panel would probably buckle
Steel side panel will need to sturdy to begin with... You can try to drill more screw holes in the sidepanel to reinforce
Worse case you will need to reinforce the side panel and or find a way to weigh down the case..
Another concept would be to use an L brace on the case but it will mean you need to screw to the table... This would ensure case wont topple over...
Processor
i5 4690K @ 4.6 GHz / Cooler Master Nepton 240M / 4 x Noctua P12 Push-Pull
Mainboard
Asus Maximus VII Hero
Graphics Card
Asus STRIX GTX1070 SLI
Memory
2 x 8gb 1866Mhz Crucial Ballistix Elite
Display
3 x Asus VG248QE 144Hz / TS473 Triple Monitor Stand
Storage
2 x 240GB on RAID0 (Boot) & 1 x 120GB (Capture) OCZ Vertex 3 / 2 x WD Green 2TB (Storage)
Optical Storage
Logitech G19, G13, G500s, G600, G940, Extreme 3D Pro, Attack 3, Rumblepad 2, MOMO Wheel, & C920
Casing
Cooler Master HAF 932 Advanced / Lamptron FC9 / 4xP14; 5xS12B; 1xP12
PSU
Cooler Master V1000 Pro
Audio
Logitech G231 Headset / Z623 2.1 THX Certified Speakers
OS
Win10
Mycrus is offline   Reply With Quote
Old 22-09-2012, 12:13 PM   #6
NSW
NSW's Avatar
I am still researching my build since I have been out of touch for a tad too long..
for eg.. I did not think of the problem mentioned, that alu side panel will buckle...
Processor
i5-3570
Mainboard
AsRock H77M
Memory
DDR3 16gb
Display
LG IPS 236V
Storage
Casing
Silverstone TJ08-E
OS
Win8.1 x64
Old 30-09-2012, 02:55 PM   #7
wouldn't be the case be too brittle?
kimyang is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
