USB printer goes offline when it is connected to Anker 10 Port 60W USB HUB
zillah
ear Experts
Recently I bought Anker 10 Port 60W Data Hub with 7 USB 3.0 Ports and 3 PowerIQ that connected to my windows 7 Desktop (Hub gets power form AC )
https://www.amazon.com/gp/product/B00VDVCQ84/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
When i connect my canon pixma MP230 USB printer it goes offline (Yes for sure) , if I connect the usb cable to computer directly the same printer will be online again
Is that because USB hub doesn't supply enough power to the printer (tried many ports),,,,,,,,,,,,I have experienced the same issue before
Thanks
Psycovirus
The 3 PowerIQ ports don't carry data. Only for charging. The other 7 ports carry data but don't supply a lot of power
Your option will be to connect to PC only.
Sent from OnePlus ONEPLUS A3000 using GAGT
commach
Deluxe Member
USb hub is merely providing a connecting interface but lack the communication with the software installed in the computer.
Hence, once the printer went offline (by design), it won't be able to online again because the software is not able to detect the voltage different when the printer connected to hub and not the USB port on the PC.
zillah
Nice shoot
Thx
