HWZ Forums
| Login | Register | FAQ | Mark Forums Read |
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems
LinkBack | Thread Tools |
#16 |
Good stuffs
![]() Might want to put a latest update dated as of when and correct some typo like.. "Total ~ $55590" ![]() |
#17 |
I see the entry system .. machiam more powerful than the one i using now... Except for casing... lol...
__________________
#18 |
I thought about it but there seems to be no performance 1GB RAM around, the only Corsair TWINX2048 (2GB) are PC3200 DDR400. Anyway, I thought 1024MB sticks were even harder to overclock than 512MBs? |
#19 |
Nice buyer's guide... Care to include X2, Pentium D or Pentium Extreme Edition (PEE)? I haave to break up post #1 in the original thread to 4 or 5 posts. Updating prices is a nightmare. It is easier to update in one single post. CPU & GC prices has dropped recently http://forums.hardwarezone.com/showt...s#post15157413 After reading again huh, i find tt i see less info leh... ![]() Last edited by adrianlee; 25-08-2005 at 12:27 PM.. |
#20 |
Good stuffs ![]() |
#21 |
Ask RAM GUY for help Will do. ![]() |
#22 |
Pentium Extreme Edition is in the DIY section. X2 & PD will be included at a later date |
#23 |
Bro adrian, IMO you should put Plextor optical drives up for the extreme system category. Just my 2 cents.
#24 |
might also want to post for systems on AMD Athlon64 3000+ - 3200+ ... shld call low end...
#25 |
Bro adrian, IMO you should put Plextor optical drives up for the extreme system category. Just my 2 cents. Most people are going for BenQ 1640, LG 4613 & Pioneer right? Any other recommendations? Last edited by adrianlee; 26-08-2005 at 08:59 AM.. |
#26 |
might also want to post for systems on AMD Athlon64 3000+ - 3200+ ... shld call low end... Under budget system you will see the AMD Athlon64 3000+ . You can replace the 3000+ with a 3200+, 3500+ ............. |
#27 |
Sorry for that... "cock" eye..
#28 |
Why mostly all recommend the MSI boards?? Why not others ?
__________________
[SIZE=1]Mada Mada Dane ~~~[/SIZE] |
#29 |
Why mostly all recommend the MSI boards?? Why not others ? Actually I prefer DFI But you can find Abit, ASUS DFI etc in DIY section of the buyers guide |
#30 |
speaking of MSI boards, wad about the RS480M2-IL?
| This forum is moderated by volunteer moderators who will react only to members' feedback on posts. Moderators are not employees or representatives of HWZ. Forum members and moderators are responsible for their own posts.
Please refer to our Terms of Service for more information. |
Previous Thread
Next Thread
| Thread Tools | |
