HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 2
Like Tree401Likes
Closed Thread
LinkBack Thread Tools
Old 27-04-2012, 11:35 PM   #1501
Hi moneyface, where did u get the I5 3450 + Asus mb combo price of $360? TIA.
Buy unspecified ones and build at PC Themes.
Lordzephyr9 is offline
Old 28-04-2012, 01:02 AM   #1502
yes bro..windows 7..help me pls
momo11 is offline
Old 28-04-2012, 01:43 AM   #1503
MoneyFace =p's Avatar
CPU+MB: Intel Pentium G850 + ASUS P8H77-M LE @ $218
RAM: G.Skill NT DDR3-1333 CL9 4GB [SATA III] @ $27
HDD: Hitachi Deskstar 7K1000.C 500GB [SATA III] @ $108
ODD: LG 24X CD/DVD Writer [OEM] @ $25
PSU: FSP Hexa 400W [80 Plus] @ $59
CASE: Haial M380-100 @ $45
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $120
Total: $602
Assembly: $10
Buy and build from PC Themes.
MoneyFace =p is offline
Old 28-04-2012, 10:38 AM   #1504
I can't locate it under the price list.
ting is offline
Old 28-04-2012, 10:51 AM   #1505
Reason is because NDA. You may ask them for the pricing.
Old 28-04-2012, 10:52 AM   #1506
$face bro, Which casing will u recommend? silverstone FT02 or corsair 550D? in terms of cooling ability and noise level which is better?
Old 28-04-2012, 01:33 PM   #1507
Was quoted $405!
ting is offline
Old 28-04-2012, 01:36 PM   #1508
Was quoted $405!
Fortran's quotation.
__________________
mF.reverie // MF wishes all a $$$$$ CNY!
Old 28-04-2012, 02:49 PM   #1509
Ya! U mean they quote higher for him!? Any walk in will be $360??
ting is offline
Old 28-04-2012, 03:50 PM   #1510
No fortran quote $360...
__________________
Old 28-04-2012, 03:56 PM   #1511
hmm....something is wrong then...i was corresponding w him
ting is offline
Old 28-04-2012, 07:24 PM   #1512
Lycanista's Avatar
Hi, my friend has a budget of +/-1k, probably using it for D3, DOTA 2, HON. I don't think he needs Windows 7 for now.
Lycanista is offline
Old 28-04-2012, 10:09 PM   #1513
NoTimeToWaitAr's Avatar
Hi guys, i'm having a dilemma.
Should I go for
1. CPU+MB:
i5 2320 Asrock H61M/U3S3 or i5 2320 GIGABYTE H61M-USB3-B3 ?
2. PSU:
Seasonic 520w or Superflower 550w?
3. GPU:
HD7850 2G OC or HD7850 2G or GTX560ti 1G or GTX560 1G OC or GTX560 2G?
Currently my monitor is 19'' 1400x900. Maybe going of upgrade to 23'' during June IT Show.
Going to keep my budget below 900. I've already have a case, HDD and OS.
Hopefully to max D3, GW2, and my next upgrade will be when my component start giving me problem .
Any advice?
Thanks in advance
NoTimeToWaitAr is offline
Old 28-04-2012, 10:49 PM   #1514
CPU+MB: Intel Core i5-3570K + Gigabyte GA-Z77X-D3H @ $550+
Motherboard offers 4th year warranty.
RAM: G.Skill NT DDR3-1333 CL9 4GB [Black PCB] X2 @ $54
GPU+PSU: Palit GTX 680 2GB + FSP Aurum CM 650W [80 Plus Gold] @ $849
SSD: Intel SSD 520 120GB [SATA III] @ $230 (VRForums)
Comes with 5 years international warranty.
HDD: Western Digital Caviar Green 2TB [SATA III] @ $168
ODD: HP 24X CD/DVD Writer [Retail] @ $28
CASE: NZXT Phantom 410 @ $159
Total: $2038+
Optional:
DSP: Philips 237E3QPHSU 23" LED [eIPS] @ $279
Assembly: $10
Promotions in BOLD.
1) 120GB is enough for OS + essential programs + some 6-10 games you name it. Use HDD as personal data storage drive.
2) Maybe you should consider some eIPS panel based monitors that boasts great colour reproduction and wide viewing angle. Even though response time may not be as good as traditional TN panel but many have proven minimal ghosting effect with games.
Hi, Moneyface. thanks for the advice. Just want to clarify a few things:
I dont really OC. so would it be better for me to get i7-3770 instead of i5-3570k?
darkvalkyries is offline
Old 28-04-2012, 11:48 PM   #1515
3770 is not available at the moment. u may have to wait till june.
get 3550 or 3570?
Closed Thread
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
