HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 2
Like Tree401Likes
Closed Thread
LinkBack Thread Tools
Old 17-09-2011, 08:19 AM   #61
If you are not planning to oc your cpu, is watercooling needed for your gpu and other parts. For example, a higher end gpu like the gtx580.
memories31 is offline
Old 17-09-2011, 08:26 AM   #62
JeNoVa-IcHiGo's Avatar
Let's say we get...GTX 590 instead, and make it liquid cooling. what's the minimum budget it would be?
JeNoVa-IcHiGo is offline
Old 17-09-2011, 08:33 AM   #63
Does budget includes for monitor, speaker and peripherals?
Intend to OC?
Hi Moneyface,
Budget is purely for CPU and components. Monitor/speakers/peripherals and software all taken care of. And I have no intention to OC. Thanks!
wolfgangs246 is offline
Old 17-09-2011, 12:08 PM   #64
hlw8888's Avatar
hi,
is it possible to build a z68 sandy bridge setup with ard $500 +- $50?
only need to include mobo, cpu, ram and if possible a decent gpu for causal gaming.
__________________
Nikon D300|18-55mm|50mm f/1.8|Sigma 70-300mm
Kpop Girl Groups Jjang!!!
hlw8888 is online now
Old 17-09-2011, 12:17 PM   #65
cyberwave's Avatar
hi,
why do you need a z68 setup? need SRT or Lucid Virtu?
cyberwave is offline
Old 17-09-2011, 12:22 PM   #66
hlw8888's Avatar
not that familiar with intel setup, googled abit to find out z68 is like the latest so ask ard to see if it is possible.
if not necessary be z68, wat would u recommend?
__________________
Old 17-09-2011, 12:27 PM   #67
cyberwave's Avatar
Generally
H61 boards : 2 ram slots, no RAID support, able to support integrated graphics, no OC capabilities, NO USB 3/ Sata 3 (Some boards like AsRock H61/U3S3 has USB 3 & Sata 3 as AsRock put in a third-party controller)
H67 boards : 4 ram slots, with RAID support, able to support integrated graphics, no OC capabilities, has usb 3 & sata 3
P67 boards : 4 ram slots, with RAID support, unable to support integrated graphics, with OC capabilities, has usb 3 & sata 3
Z68 boards : 4 ram slots, with RAID support, able to support integrated graphics, with OC capabilities, has SRT, has Lucid Virtu, has usb 3 & sata 3
Old 17-09-2011, 01:29 PM   #68
hlw8888's Avatar
Generally
oic. thks for the clarification.
seems that maybe H67 will suit me better. may i ask, how impt is integrated graphics? for standby purpose?
__________________
Old 17-09-2011, 11:27 PM   #69
MoneyFace =p's Avatar
Hi Moneyface,
Sorry to ask. Perhaps can you also tell me your colour likings, preferred chassis location and want to crossfire/SLI?
__________________
mF.reverie // MF wishes all a $$$$$ CNY!
MoneyFace =p is offline
Old 18-09-2011, 12:14 AM   #70
Hi MF,
Umm preferred chassis color would be NZXT Phantom black color? chassis location is on the floor and I'm neutral on the crossfire/SLI. I understand crossfiring can result in higher performance for lower cards but also that the tech is still not fully utilized by some games.
Thanks!
Old 18-09-2011, 12:56 AM   #71
Hi MF,
Thanks!
Single-GPU solution
CPU+MB: Intel Core i5-2400 + Gigabyte GA-Z68XP-UD3-B3 @ $473
RAM: G.Skill DDR3-1333 CL9 4GB [Black PCB] X2 @ $50
GPU: ASUS GTX 580 1.5GB DirectCU II @ $699
This card provides unrivaled acoustics and cooling performance.
SSD: Crucial RealSSD M4 128GB [SATA III] @ $324
HDD: Hitachi Deskstar 7K1000.C 1TB [SATA II] @ $68
ODD: Sony Optiarc 24X CD/DVD Writer [Retail] @ $29
PSU: FSP Aurum 650W Modular [80 Plus Gold] @ $159
CASE: NZXT Phantom [Black] @ $188
Optional:
GPU: EVGA GTX 580 1.5GB Superclocked @ -$100 (Fuwell, Bell Systems)
If you want more value for money and does not mind noise.
SSD: OCZ Vertex 2 180GB [SATA II] @ +$115
With the above change, you can get a larger capacity SSD to squeeze in more games.
Total: $1990
Multi-GPU solution
CPU+MB: Intel Core i5-2500K + Gigabyte GA-Z68XP-UD3-B3 @ $510
You are advise to overclock to maximise the crossfire solution's potential.
GPU: Sapphire HD 6950 1GB Dirt3 X2 [CrossFireX] @ $650
PSU: FSP Aurum 750W Modular [80 Plus Gold] @ $179
Total: $1998
Optional:
HSF: Cooler Master Hyper 212 Plus @ $49
When you want to overclock.
Buy all from PC Themes unless specified in brackets.
__________________
Old 18-09-2011, 10:34 PM   #72
Single-GPU solution
Optional:
Total: $1990
Multi-GPU solution
Total: $1998
Optional:
Hi MF,
Thanks for this recommended setup!
Old 18-09-2011, 10:43 PM   #73
Hi, need a recommended set up for video encoding and light gaming.
Must have:
VGA and HDMI
Blue ray disc drive
Budget: 500
Please provide break down of price as well. No need OS. Just rig.
k.a.e.e.l is offline
Old 18-09-2011, 10:53 PM   #74
Must have:
VGA and HDMI
Blue ray disc drive
Budget: 1k
edit: -deleted-
buggerbuggerbrinjal is offline
Old 19-09-2011, 07:23 PM   #75
Must have:
VGA and HDMI
Budget: 500
Hi,
Anybody got any idea?
Closed Thread
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
