Power Supply Buyer's Guide
Chong Yu Fu
Now i set up My system:
Asus P8H61-MPRO
Intel I5 2.9ghz
4gb 1333mhz kingston
with a
CoolMaster 500w PSU
Planning to purchase the new samsung 3d full hd monitor,
any recommendation of 3d gfx available?
Too much choice on the market..
Can i add a sound card and a 3d gfx with my PSU?
will it be sufficient?
BryanWu
what model is your coolermaster.. if its extremepower, then limit your gfx to a mid range one that requires only 1pci-e 6pin.. eg. 6770 etc.. but it might not be enough for full hd gaming
t258jgn
Deluxe Member
Bryan Guru
i7-2600k
Zotac Z68
8gb 1866 ddr3
Corsair Force GT ssd
3x Hitachi 3TB HDDs
FSP 300W SFX
No OC
What is the max gfx card I can use for
1) Nvidia
2) AMD
Thanks
takuyazzz
Hi, can recommend a psu for the following spec? Seems like fsp aurum is the most highly recommended. How about Andyson, OCZ, Enermax or Seasonic PSUs?
i5 2400
Biostar P67b+
Palit gtx460
2x kingston 4gb ddr3 ram
2x sata3 hdd
1x dvd-rw drive
1x pci soundcard
zzz_hole
Hi,
got a question regarding electricity consumption.
E.g. a PC with a 500w PSU, running 300w idle and 400w full load.
If this PC is left running idle for 1hr and full load for 2 hrs consecutively, how will the electricity bill be calculated?
(taking SP services rate as 0.2919cents/KWh)
a) [(300/1000)*0.2919]+{2*[(400/1000)*0.2919]}
b) 3*(500/1000)*0.2919
BryanWu
a) but it depends on efficiency also..
75% efficient at 300wDC = 400w AC from wall socket..
75% efficient at 400w = 533w from wall socket
(500w limit is DC, not AC but you are billed using AC draw)
90% eff at 300w DC = 333w AC
90% eff at 400w DC = 444w AC
Total for 75% eff psu = 400/1000*0.2919 + 2*533/1000*0.2919 = $0.428
Total for 90% eff psu = 333/1000*0.2919 + 2*444/1000*0.2919 = $0.356
DIfference = 20% higher bills
adrianlee
Super Flower Golden King 1000W Review
Super Flower is a manufacturer, headquartered in Taiwan but with their factory in mainland China, that's been around making computer chassis and power supplies for quite a long time. Unfortunately, the brand has not been available in the U.S. for some time, although Super Flower units can still be purchased all over Europe and Asia. Here in America, we usually have to wait for a company like Kingwin or Sentey to pick up and re-brand a unit.
The Golden King is the first power supply I've had a chance to review that advertises 80 Plus Platinum efficiency. That means this power supply should be at least 90%, 92% and 89% efficient at 20%, 50% and 100% loads. We will certainly try to confirm this in today's tests.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=252
Arcanda23
Hi, My psu just died and my friend recommend me this two brand. Antec Earthwatts EA-500D or seasonic s12 ii bronze 520w.
Seems that I can't find seasonic in sim lim. Anyone know where can I found it? or is there any brand with similiar quality?
adrianlee
Kingwin Stryker Fanless 500W Review
Not very long ago, I took a look at a fanless power supply from Superflower that turned out to be the bee's knees when it came to providing stable power at very high efficiency without so much as a cooling fan to help it. At the time, I wished and pined for this unit to come to the North American market, since you cannot buy any Superflower retail units on this continent. Well, Kingwin has granted my wish. They are now offering their own version of this awesome unit which goes by the name Stryker. Let's see if anything has changed about the design.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=253
adrianlee
RIp~Shan
Okay Hello Ladies and Gentlemen,
I was not sure where to post this query so I'll just post it here,I am currently forming a new DIY Rig OC intensive, Thus saying that I am not sure what type of Power Supply and at what Watts, I want a good lasting what at the same time cost efficiency. I'll post the Rig's Spec below
CPU
Intel Core i5-2500k
CPU Coolers
Thermal Right Silver Arrow
RAM
Kingston Hyper X-Dual-Channel DDR3 @ 1600MHz C9 4Gb X2
Motherboard
Asus Z68 V Pro
Graphics
ASUS GTX580 DirectCu II 1536MB GDDR5
Display
W2242 (1680x1050@60Hz)
Hard Drives
Seagate 1TB 7200/32MB/SATA3
OCZ Vertex 3 SSD 60GB
Optical Drives
Asus 24X SATA SuperMulti
I am going to OC this baby till she's banged for bucks! With this said I don't think I am going to SLI this Rig soon but if i do what Watts to get and if i don't what Watts to get. Thanks I appreciate the the quotes.
xtwis7
Deluxe Member
Without SLI, take 600W gold at least. With SLI, go up to 850W to be comfortable.
kenjikuro
hmmmm which power supply can hold
35A - 12v = 420w
30A - 5V = 150w
currently all i see is 24A for 5v
adrianlee
Enermax Platimax 1200W Review
Not too long ago, Enermax contacted us with an opportunity to review their new 80 Plus Platinum certified, fully modular power supply, the Platypus... err... sorry.. The Platimax. The Platimax is an upgrade over Enermax's 80 Plus Gold effort, the MaxRevo. Needless to say, we wanted the chance to see if the Platypus.. sorry... Platimax performed at least as well as the MaxRevo, but with better efficiency...
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=255
