HWZ Forums
Login Register FAQ Mark Forums Read
Power Supply Buyer's Guide
Like Tree5Likes
Reply
LinkBack Thread Tools
Old 09-05-2014, 12:11 AM   #331
allhomme's Avatar
can Corsair AX 1200i run 3 GPUs?
I am trying to run
1 MSI 7970
1 Saphire 7970
both run fine but when add Asus R9 280X Direct CU II , display does not come up when start computer....
Any help
I don't know about the power consumption of the R9 280X but I was using OCCT power supply tester to test my GTX770 SLI overvolt @ 1212mV and OC to 1306MHz and 4770K OC to 44x, peak power consumption on the AX1200i according to Corsair Link was 650+ Watts.... avg was in the high 500W
Just a ball park figure for you reference.
allhomme is offline   Reply With Quote
Old 15-08-2015, 03:28 PM   #332
Hi, is fsp450-60ep enough to run Asus GTX 750 ti oc? If not what is recommended for me and please advise in the price thanks
Rgyl11 is offline   Reply With Quote
Old 29-04-2016, 07:07 AM   #333
Hey, corsair cxm 600w 80+ bronze vs seasonic x650w 80+ gold
Which one is better? And why its better than other
RoyceSmith is offline   Reply With Quote
Old 03-05-2017, 10:59 PM   #334
sjvkmr's Avatar
Red face
It really depends on what components you are using your PSU with. But 650w not only sorta 'futureproofs' your build, it the gold certification makes this psu a more energy efficient than the corsair model despite the 50w difference. Hope this helps.
sjvkmr is offline   Reply With Quote
Old 26-07-2017, 07:04 PM   #335
Any reviews about the new cooler master MWE 400,450 and 500 series? Seems cheap and promising. Or is it like the elite series where it's not recommended?
Sent from Xiaomi REDMI NOTE 4 using GAGT
~Dragonite~ likes this.
limjialok is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
