HWZ Forums
Login Register FAQ Mark Forums Read
Water Filtration System
Like Tree2Likes
  • 1 Post By ntec66
Reply
LinkBack Thread Tools
Old 25-06-2014, 01:25 PM   #1
vuzuuu's Avatar
Hi, I"m thinking to get one for my new place, which one is good?
Diamond, Amway Espring, Novita and etc are available in Singapore market, do we really need this kind of equipment to filter singapore water, I"m health conscious and won't mind to spend some money for good health.
Thanks.
vuzuuu is offline   Reply With Quote
Old 25-09-2014, 12:22 PM   #2
Hi, if you are still looking for a Water Filtration System. please do PM me. Thank You.
peacemakerho is offline   Reply With Quote
Old 03-10-2014, 01:02 PM   #3
We have had diamond for about 10 years. Now it is time to change all the filter, basically it will cost the same as buying a new set. I find maintenance is expensive. Was looking at other system, heard that AOX is good. Very expensive though. Anyway, we decided to do without and see if there is difference. Our rationale is that Singapore water is of good quality, alkaline can be added to our water by adding lemon and the claimed smaller molecule size water of some machine is arguable
Anyway, most of the company offer free trial. Just try and see.
happymum is offline   Reply With Quote
Old 16-07-2016, 12:34 AM   #4
Any one using Novita water filter system? Could you sure your views on this?
Does the dispensing of the different pH of water really makes a difference? Tia
crunsik is offline   Reply With Quote
Old 19-06-2017, 11:51 PM   #5
Singapore water is so clean, no need to spend so much on fancy water filters when a low-budget one is sufficient.
A sediment filter to remove particles and a carbon filter to improve taste is all you need.
I got this in Johor at less than S$50. Best feature is we can see the filter condition as it is transparent.
And the replacement filters are dirt-cheap and sold in bulk there.
https://eshop.tesco.com.my/groceries...cts/7070408432
~Dragonite~ likes this.
ntec66 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
