HWZ Forums
Login Register FAQ Mark Forums Read
HardwareZone.com on Facebook
SAMSUNG 2D / 3D LED MONITORS
Like Tree1Likes
Reply
LinkBack Thread Tools
Old 24-08-2011, 11:39 AM   #1
Momentum-Skills's Avatar
Smile SAMSUNG 2D / 3D LED MONITORS
Hi All
SAMSUNG is now released the current few models of 2D / 3D LED Monitors. Models will be stated as below:
1. S19A300B - 18.5" LED MONITOR (VGA/DVI)
2. S20A300B - 20" LED MONITOR (VGA/DVI)
3. S22A350H - 21.5" LED FULL HD MONITOR (VGA/HDMI)
4. S23A350H - 23" LED FULL HD MONITOR (VGA/HDMI)
5. S24A350H - 24" LED FULL HD MONITOR (VGA/HDMI)
6. S23A550H - 23" LED FULL HD MONITOR (VGA/HDMI)
7. S27A550H - 27" LED FULL HD MONITOR (VGA/HDMI)
8. S23A950D - 23" LED FULL HD 2D-3D MONITOR (DVI/HDMI/DISPLAY PORT)
9. S27A950D - 27" LED FULL HD 2D-3D MONITOR (DVI/HDMI/DISPLAY PORT)
9. C23A750X - 23" LED FULL HD WIRELESS HUB CENTRAL STATION MONITOR (VGA/HDMI/USB 4 PORTS)
10. C27A750X - 27" LED FULL HD WIRELESS HUB CENTRAL STATION MONITOR (VGA/HDMI/USB 4 PORTS)
11. T27A950A - 27" LED FULL HDTV 2D-3D MONITOR (2 HDMI/1 USB/DIGITAL TV TUNER)
Upcoming SAMSUNG LED MONITORS will be releasing soon. Models will be stated below:
1. Series SA450B
2. Series SA650D
3. Series SA750D
4. Series SA850D
There will be showrooms for showcase of SAMSUNG LED MONITORS at:
1. SAMSUNG EXPERIENCE CORNER BOOTH - SIM LIM SQUARE, Level 3
2. SAMSUNG @ CYBERMIND - FUNAN DIGITALIFE MALL, Level 4
3. SAMSUNG FLAGSHIP STORE - VIVO CITY, Level 2
Do check it up soon!
Any enquiries, do post it here!
Have a nice day ahead!
__________________
Best Regards
Monitors/Printers Products Specialist
chiamyifa@gmail.com
Momentum-Skills is offline   Reply With Quote
Old 29-08-2011, 11:05 AM   #2
Look at S24A650D, heard 24A850D not so soon on comex. Bobian unless pls much better than mva.
Can advise 24a650D price and which booth?
stanley47 is offline   Reply With Quote
Old 29-08-2011, 12:03 PM   #3
Hi Stanley47
For the latest Series of SA450B, SA650D, SA750D and SA850D won't be releasing soon. You may wait until mid-September to be offically Launched.
Thanks.
__________________
Best Regards
chiamyifa@gmail.com
Old 29-08-2011, 01:06 PM   #4
But cybermind got sell S24A650D in simlim.
So u mean 24inch non-TN panel monitor not available at comex?
27 too big for me, 24 just nice with 16:9.
Old 29-08-2011, 02:29 PM   #5
Hi Stanley47
Yes, currently only store is Cybermind in Sim Lim Square do carry S24A850D and S27A850D. But not sure whether they do carry or have the stocks of S24A650D.
You may check with them.
Thanks.
__________________
Best Regards
chiamyifa@gmail.com
Old 29-08-2011, 03:17 PM   #6
Hi,
Any Samsung models that are 16:10 aspect ratio, non 3D , LED 23-24inch with 1080p 1920x1200 native display?
Vodkilla is offline   Reply With Quote
Old 29-08-2011, 04:11 PM   #7
Hi,
Hi Vodkilla
In the past, SAMSUNG Monitors do have this functions but currently don't have. If you want to have a SAMSUNG Monitor with Aspect Ratio of 16:10, only LCD 22" B2240W with the Resolution of 1680 x 1050p or LCD 24" B2440MH with the Resolution of 1920 x 1080p.
Thanks.
__________________
Best Regards
chiamyifa@gmail.com
Old 29-08-2011, 05:39 PM   #8
sgstab's Avatar
Highly interested in S24A850DW as not intend to get 27inch, mind pm price for this model?
Cybermind dont have this model, they carry 27A850D only.
__________________
BUY/SELL IPHONE / iPADs in qty
sgstab is offline   Reply With Quote
Old 29-08-2011, 09:26 PM   #9
algerr's Avatar
Hi TS, need to ask some qns:
currently, I am looking at the 23" monitors:
1. what's the advantage about having 120Hz instead of 60Hz? which model has 120hz?
2. The 3D thing - is it automatically enabled all the time ?
3. I do not really need the 3d thing, so can it be turned off manually?
4. if I used the dvi-HDMI adapter to connect my dvi graphic card to HDMI input of monitor - does that mean I get to have the HDMI picture quality?
5. saw a few series.. T and S series.. what's the difference?
Sorry for posting so many questions, cos looking for monitor to replace current one which is spoiled.
Help appreciated, thanks in advance.
algerr is online now   Reply With Quote
Old 30-08-2011, 02:23 AM   #10
Hi Sgstab
Cybermind Computer House PTE LTD do carry / have the stocks for S24A850D.
Thanks.
__________________
Best Regards
chiamyifa@gmail.com
Old 30-08-2011, 02:35 AM   #11
Hi Algerr
Nice of knowing you and allow me to explain and brief you on new SAMSUNG Monitors you are looking at.
To your Points 1 & 5:
For all Brands of Monitors, be it SAMSUNG, PHILIPS, LG, VIEWSONIC, ACER, AOC, they are actually Conventional Panel at 60HZ.
Likewise if you are looking for a 120HZ which is 3D Ultra Clear Panel would be SAMSUNG 23" LED 3D FULL HD Monitor S23A950D or 27" LED 3D FULL HD Monitor S27A950D or even, 27" LED 3D FULL HDTV Monitor T27A950A. The Difference between "S" Series are only for Computer/Laptop Usuage and "T" Series are only for TV and Monitor 2-IN-1 Usuage.
To your Points 2 & 3:
SAMSUNG LED 3D SA950D Series and TA950A Series, for 3D Glasses are using ACTIVE, which means the 3D Glasses required a Lithium ION Battery to Run. First of all, you have to switch your SAMSUNG LED 3D SA950D Series or TA950A Series to 2D-3D Source Mode, after that put Lithium ION Battery into the SAMSUNG 3D Glasses, after that you have to press & hold on the "Switch" in order to synchronise and patch up to your SAMSUNG LED 3D SA950D Series or TA950A Series. The Lithium ION Battery for SAMSUNG 3D Glasses would last you up to 70 Hours. If you would like to switch off the 3D Source, you can off the SAMSUNG 3D Glasses "Switch" in order to Disconnect it.
To your Point 4:
The best way is to use HDMI to HDMI Cable of the latest Version 1.4 to connect from your SAMSUNG LED 3D SA950D Series or TA950A Series to your Computer's External Graphic Card (Provided it must have a HDMI Input), so that you will see the true of HD Picture Quality as it does support HDCP (High Definition Color Picture). There is no gurantee that if you wish to use DVI to HDMI Converter Cable to produce a HD Picture Quality.
Thanks.
__________________
Best Regards
chiamyifa@gmail.com
Old 30-08-2011, 07:58 AM   #12
algerr's Avatar
ah...I see...
Thanks for clarifying my doubts promptly.
Time to hit the comex show to take a look.. =)
Old 30-08-2011, 10:58 PM   #13
es0teric's Avatar
TS, if I get the 27 inch TV version, will I able to see every channel in 3D?
es0teric is offline   Reply With Quote
Old 31-08-2011, 10:57 AM   #14
Hardware Clinic, Storage Clinic, Apple Clinic & Sub-forums
BL-inside's Avatar
Hi All,
Slight corrections here.
Best Denki WILL be carrying this 3 models into Comex, though with limited stocks, at Level 3.
S22A460BW
S24A650D
S27A850D
Thanks~
__________________
Ban Leong Technologies Limited
150 Ubi Avenue 4, Unit #04-01. UBI Biz-Hub. S (408825)
Service Centre Opening Hours - Mon to Fri: 0900 - 1700, Sat: 0900 - 1230, Closed On Sundays & Public Holidays.
Tel: 65129221 (Mainline), 65129250 (Service)
Please do indicate product brand in your header when sending us PM. Thanks
Like Us On Facebook To Get The Latest Updates And Promos!!
Cooler Master Singapore
Power Color Singapore
eRegister your products here
BL-inside is offline   Reply With Quote
Old 01-09-2011, 04:54 PM   #15
sgstab's Avatar
Camping here for S24A850D, 850 series really nice color and satuated.
PLS defeat me.
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
