HWZ Forums
Login Register FAQ Mark Forums Read
Need help with my Wifi setup
Reply
LinkBack Thread Tools
Old 31-03-2014, 12:51 AM   #1
ahsiao80's Avatar
Hello peeps!
My Singtel 300mbps fibre is coming soon and I'm hopping people in this forum can assist me on the preparation of the Wifi in my house. i understand the modem Singtel provide will only have a max speed of 110mbps for wifi, so any solution to get the max out of it?
My TP is in the living room and I'm using my MBP Retina (Without Ethernet port) in my room which is about 5M away max from the modem.
Appreciate all help in-advance, thanks!
__________________
Don't Cry Because Its Over, Smile Because It Happened.
"So Others May Lived"
ahsiao80 is offline   Reply With Quote
Old 31-03-2014, 09:57 AM   #2
azrin619's Avatar
fix lan cable to yr room n run another router as ap
__________________
--Tech Qns @82089180--
Lost my old number..
azrin619 is offline   Reply With Quote
Old 31-03-2014, 11:31 AM   #3
ahsiao80's Avatar
But mine house will become very ugly >.<
__________________
Old 31-03-2014, 12:03 PM   #4
5M away.. should be no prob with coverage. Speed - i doubt there is any chance to hit 300 mbps on WiFi. Personally I'll be quite happy if I can get 50Mbps
bazingaman is offline   Reply With Quote
Old 31-03-2014, 06:26 PM   #5
wireless-ac
__________________
https://onedrive.live.com?invref=f158d1d76c3a2354&invscr=90
j_t_fusion is offline   Reply With Quote
Old 31-03-2014, 06:44 PM   #6
Rashkae's Avatar
140ish will be the fastest you can get. Very wasted to get 300 and only use wifi
Rashkae is offline   Reply With Quote
Old 31-03-2014, 06:49 PM   #7
ahsiao80's Avatar
really ah? then you recommend to get 200 if I'm using wifi?
__________________
Old 31-03-2014, 07:51 PM   #8
azrin619's Avatar
If you do properly...won't be ugly la bro...won't have wires running about....
Anyway..Wifi max is 140mbps or so even on AC...as I heard ASUS is getting into trouble exceeding the power transmission
__________________
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
