HWZ Forums
Login Register FAQ Mark Forums Read
Singnet Fibre Optic Broadband Speed Discussion
Like Tree2509Likes
Reply
LinkBack Thread Tools
Old 05-10-2010, 08:33 PM   #16
I am using a gigabit network adapter. If I am using wireless connection, will there be a significant slowdown in speed as compared to cabled connection? The problem with cabled connection is that you have to do trunking from the living room to the study room. The best is to wall hack and run the cable concealed. Is there any alternative solution?
newkidontheblock likes this.
Jamesykl is offline   Reply With Quote
Old 05-10-2010, 09:39 PM   #17
FIREBOWS's Avatar
Use one pair of Homeplug then
FIREBOWS is offline   Reply With Quote
Old 05-10-2010, 11:16 PM   #18
seeyourhead_jiejie's Avatar
y sian? 37mbps to los angeles seems really gd leh.. considering that international bandwidth is capped at 25mbps
mayb not really have a cap on the speed? they juz put it to protect themself so users wont complain low oversea speed ?
can those singnet fibre user do a multi segment download with download manager from oversea servers ? what the speed you can get ?
seeyourhead_jiejie is offline   Reply With Quote
Old 06-10-2010, 01:14 PM   #19
lestervalen's Avatar
Hi James, as requested. Busy with work lately, this time uses another PC to try with 1.5m cable direct to giga port.
San Jose is real pain to past through highest speed as below
lestervalen is offline   Reply With Quote
Old 06-10-2010, 06:51 PM   #20
can you do a test upload to hotfile or rapidshare?
Kapish is online now   Reply With Quote
Old 06-10-2010, 07:08 PM   #21
sorry for the noob questions, what are the speed of the broadband you guys are using?
__________________
PSN: afr0v1l
afrovillain is offline   Reply With Quote
Old 06-10-2010, 10:17 PM   #22
Just out of curiosity, how do you run the cable to your pc? You ask Singnet engineer to do it or all by yourself?
Old 07-10-2010, 02:33 PM   #23
yodajedi01's Avatar
I'm not sure why i'm not getting my high speed.
i'm getting less than 100Mbp in SG.
I'll test again tonight.
if not will call up singnet again for an answers ....
__________________
MacMini 2012 w/ Samsung 850 EVO 250 GB
iMac 2017 27" 5K 256SSD
yodajedi01 is offline   Reply With Quote
Old 07-10-2010, 07:42 PM   #24
Wireless connection will definitely be slower than cabled connection. Check whether your configuration.
Old 08-10-2010, 10:46 AM   #25
yodajedi01's Avatar
yes, but even on direct connection?!!!!
I'm surprise.
now beside the speed issue,
i need to figure out how to reconfig my Synology NAS to for a DDNS storage.
(not sure if it that ppoe need to be set)
__________________
Old 08-10-2010, 01:29 PM   #26
Perhaps you're using Cat 5 cable bro.
Switch to Cat5e or Cat 6
alvinleong01 is offline   Reply With Quote
Old 08-10-2010, 02:42 PM   #27
yodajedi01's Avatar
Perhaps ...
but i did try using Cat5e from the ONT to RG to system ... same
let me try again one more time, b4 i call up them for on-site service.
__________________
Old 08-10-2010, 04:23 PM   #28
AC2
it could be your gigabit network adapter also. I was using the build-in gigabit adapter from gigabyte motherboard and i only manage to get 33-60 Mb/s download 89-95Mb/s upload on the singnet utilities website. However, I can reach 93-98 Mb/s download 113 Mb/s upload on Speedtest.net website.
Then I went to install a TP-link gigabit adapter on the PCI slot on the motherboard and I am able to get 135 Mb/s download and 98 Mb/s upload on speedtest.net(sg server)
I remember the singtel guy's laptop can hit 198 Mb/s download 94 Mb/s upload on my fibre. But I cant get that on my System... Not sure what went wrong
-Cable used is Cat 6 btw
Tried a few times back to back. result is the same.
AC2 is offline   Reply With Quote
Old 08-10-2010, 08:21 PM   #29
yodajedi01's Avatar
I remember the singtel guy's laptop can hit 198 Mb/s download 94 Mb/s upload on my fibre. But I can get that on my System... Not sure what went wrong
Lol
weird, my test both singnet utilities & Speedtest gave me almost the same result
Really less than 50+++
both macmini and my Asus eeePC 100HA. Both have Gigabit lan port.
Both lan and wireless.
Best is use Cat6 but on a normal Cat5 cable, i don't think it's that REALLY BAD
__________________
Old 09-10-2010, 12:01 PM   #30
AC2
could it be because or proxy issue? I am not using any. Does it help to increase speedtest.net connection speed? Maybe the engineer's laptop are using proxy that why so high?
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
