HWZ Forums
Login Register FAQ Mark Forums Read
Singnet Fibre Optic Broadband Speed Discussion
Like Tree2509Likes
Reply
LinkBack Thread Tools
Old 09-10-2010, 01:29 PM   #31
lestervalen's Avatar
Just out of curiosity, how do you run the cable to your pc? You ask Singnet engineer to do it or all by yourself?
Yes all work was done by Singtel cable & trunking no extra charge.
newkidontheblock likes this.
lestervalen is offline   Reply With Quote
Old 09-10-2010, 10:10 PM   #32
Just had my Singnet fibre optic connection hooked up. Trunking to study room done by cabling guy accompanied with group of Singnet engineers armed with laptop to do speedtest. Here's my speedtest:
Jamesykl is offline   Reply With Quote
Old 09-10-2010, 10:13 PM   #33
can you do a concurrent download from rapidshare or hotfile?
Kapish is offline   Reply With Quote
Old 10-10-2010, 01:16 PM   #34
You need to have a gigabit adapter to show that the speed is 1 Gbps.
Old 10-10-2010, 03:21 PM   #35
yodajedi01's Avatar
I thnk i Know what is wrong with my speed being slow.
Possible reason is my ONT & RG is in my Hall.
More of my Gargets are in my room.
So the best way to go about it is useing HomePlug HL280E.
test for the speed, i believe it could be due to Old wiring.
Oo well maybe some other time, I may ask them to place another Point in my room
__________________
MacMini 2012 w/ Samsung 850 EVO 250 GB
iMac 2017 27" 5K 256SSD
yodajedi01 is offline   Reply With Quote
Old 10-10-2010, 04:34 PM   #36
You need to use Cat6 or Cat5e wiring from the 2Wire to your pc to achieve the fibre speed. If you are running wireless, you can only achieve a maximum of 70 Mbps. The Singnet engineer do trunking to your room free of charge. If you do on your own, buy a Cat6 cable (best) that can run from the 2Wire to your room but its going to be expensive. A Cat5e is equally good.
Old 11-10-2010, 09:31 AM   #37
Navigator's Avatar
my installation will start today...
post my speed result later.
__________________
I Love You More Today Than Yesterday, But Not As Much As Tomorrow
Navigator is offline   Reply With Quote
Old 11-10-2010, 11:01 AM   #38
Will the speed drop when mio tv is played? Btw r we supposed to be getting any free 2 mths trial thingy? I just signed up for the exstream
Homesports
coolstardy is offline   Reply With Quote
Old 11-10-2010, 12:35 PM   #39
Some of my pingtest results. Quite good.
Old 11-10-2010, 12:56 PM   #40
yodajedi01's Avatar
Homesports
If you sign up during the roadshow @ PS.
you get 2 months FREE not 2 mths trial.
__________________
Old 12-10-2010, 08:16 AM   #41
Fantastic speedtest to US server.
Old 12-10-2010, 08:26 AM   #42
Superb connection to Asia.
Old 12-10-2010, 10:36 AM   #43
can you do a test upload to hotfile or rapidshare?
Okay. This is my download test. I do not have rapidshare account. My download speed is around 5.6 MB/s as shown below.
Uploaded with ImageShack.us
Old 12-10-2010, 10:40 AM   #44
Arucard's Avatar
Then singnet engineer using cat5e cable right? btw Jamesykl , can try to bit torrent see how the 2 wire router can handle? thanks!
Arucard is offline   Reply With Quote
Old 12-10-2010, 10:46 AM   #45
Yes only Cat5e
guangzong is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
