HWZ Forums
Login Register FAQ Mark Forums Read
Singnet Fibre Optic Broadband Speed Discussion
Like Tree2509Likes
Reply
LinkBack Thread Tools
Old 12-10-2010, 11:04 AM   #46
Arucard's Avatar
Yes only Cat5e
Cat5e no problem one , I using it to connect to my dir 655 , can archive 1gb
newkidontheblock likes this.
Arucard is offline   Reply With Quote
Old 12-10-2010, 12:47 PM   #47
Then singnet engineer using cat5e cable right? btw Jamesykl , can try to bit torrent see how the 2 wire router can handle? thanks!
Here's the bittorrent speed. Just install to try out how good it is.
Uploaded with ImageShack.us
Jamesykl is offline   Reply With Quote
Old 12-10-2010, 01:29 PM   #48
glacieraze's Avatar
try to run a few more torrents
glacieraze is offline   Reply With Quote
Old 12-10-2010, 01:55 PM   #49
it look abit underwhelming for torrent speed if u are using fiber
__________________
[SIZE=1]ViVa LaF[/SIZE]
ichitaka is offline   Reply With Quote
Old 12-10-2010, 02:42 PM   #50
seeyourhead_jiejie's Avatar
go try dl those linus disc like ubuntu
seeyourhead_jiejie is offline   Reply With Quote
Old 12-10-2010, 03:39 PM   #51
What speed is considered good? Is this good? I think it depends on the user uploading to my pc.
Old 12-10-2010, 04:21 PM   #52
Qubicfactor's Avatar
well, max I could achieve on my 10Mbps Singnet is 1.27MBps constant.
1.1MBps is respectable at any rate, but considering the above and the fact that 25Mbps international should theoretically net you around 3MBps makes it seem disappointing.
In other news, got mine installed today during lunchtime. Will go back and test mine once I reach home after work. Preliminary results seem short of what others seem to be getting (120/80Mbps speedtest for 200Mbps plan) , but maybe it's my config.
Qubicfactor is offline   Reply With Quote
Old 12-10-2010, 04:28 PM   #53
Arucard's Avatar
Same here my singnet 10mbps can reach the kind of speed you mention , I just want to see how the 2wire can handle the torrent speed.
Old 13-10-2010, 01:17 AM   #54
Those trying on torrent, did u guys open a port for it?As Qubicfactor said, I can also hit 1mb on my 10mb plan.
syc77 is offline   Reply With Quote
Old 13-10-2010, 12:30 PM   #55
t258jgn's Avatar
Atlast
__________________
t258jgn is offline   Reply With Quote
Old 13-10-2010, 06:41 PM   #56
Arucard's Avatar
When you guys start torrenting the router will slow down surfing experience? my dir655 dont have such problem
Old 13-10-2010, 06:50 PM   #57
I noticed that if you do a traceroute in dos mode, you won't be able to see the hops. After the first hop, the second hop onwards will give you ****** response. Which means that singnet may mask the servers for security reasons. Furthermore, speedtest will give unstable ping to overseas servers in US.
Old 13-10-2010, 07:37 PM   #58
pIsangpIsang's Avatar
nah the 1st 2 hops are op co internal router, they mask icmp. so u wont see any response from them.
this is bassically to hide the ip address of the router, u know there's a hop there but not the ip address. in other words hiding them from reconnaissance
__________________
A friend asked my why I need so much upload b/w, I told him 'Ion Cannon READY! Select Target!'
pIsangpIsang is offline   Reply With Quote
Old 13-10-2010, 08:03 PM   #59
t258jgn's Avatar
Will not slow down but 2Wire died after 3hrs. Have to restart the RG.
__________________
Old 13-10-2010, 08:18 PM   #60
Arucard's Avatar
wah lau , the Global Maximum connection you set to how many? I set 400 for my 655 , maybe too many connection the 2wire cannot tahan.
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
