HWZ Forums
Login Register FAQ Mark Forums Read
Surface pro usb is damaged, is there any way I cam get a usb converter for the charging port?
Reply
LinkBack Thread Tools
Old 29-07-2017, 07:55 PM   #1
thenextseeker's Avatar
Question Surface pro usb is damaged, is there any way I cam get a usb converter for the charging port?
Hi, my surface pro 3 usb port is damaged. As you know, surface pro 3 only has 1 usb port.
Is there any way I can create usb port access to the surface pro? There is a port for charging in the middle, but is there a usb converter to be connected to the charging so that I can start plugging usb again such as using a mouse?
Please advise, I tried to search online but cant seem to find such a product.
thenextseeker is offline   Reply With Quote
Old 30-07-2017, 09:04 AM   #2
yusoffb01's Avatar
i used google and i found the answer on microsoft website
__________________
There will be a time when gold can be found on Euphrates(river in iraq) and people will kill for it
yusoffb01 is offline   Reply With Quote
Old 30-07-2017, 02:02 PM   #3
still cant find any ans online or ms website, anyone has any advice?
Old 30-07-2017, 06:12 PM   #4
The simple answer is cannot... just get the USB port replaced... doesn't cost much... you don't have to go back to Microsoft to get it replaced... any laptop repair shop should be able to handle the replacement... try Sim Lim Square... I usually use PC Hospital on the fourth floor.
Teo Ming Ern is offline   Reply With Quote
Old 02-08-2017, 06:58 PM   #5
watzup_ken's Avatar
The charging port is propritory, so I unless you can find it in MS' store, otherwise you are out of luck. Try to get to fixed as recommended.
watzup_ken is offline   Reply With Quote
Old 03-09-2017, 10:14 PM   #6
Bluetooth mouse?
joesph is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
