HWZ Forums
Login Register FAQ Mark Forums Read
Add 2T motor oil to petrol.
Reply
LinkBack Thread Tools
Old 03-08-2009, 04:58 PM   #46
Mai tuu liao! Buy!
There's mineral, semi-synthetic, and synthetic.
Mobil 2T Extra is semi.
After I finish current one, I try the basic mineral type.
it was wirtten as SYNTHETIC.. but not sure whether it is semi.. the brand name is TOUR from France !
j3ffr3y is offline   Reply With Quote
Old 04-08-2009, 03:27 PM   #47
A friend added the 2T to his Sylphy, and told me the acceleration seems smoother and lighter than usual.
Update again when he re-fuels full tank and inform me of the mileage result.
CNGpicnic is offline   Reply With Quote
Old 08-08-2009, 01:06 PM   #48
Friend informed at half tank, should show 270km, but achieved 330.
At top up, pumped 6 Lit lesser petrol.
Old 08-08-2009, 04:09 PM   #49
zuoom's Avatar
adding 2-stroke oil and diesel
http://www.freel2.com/forum/topic878.html
that works apparently, and a rather common practise for diesel guys.
for petrol engine though, it's not so clear cut. there's the issue of clogging up the cat (unless you are not running one!) among other issues ie: carbon build up.
__________________
z.
zuoom is offline   Reply With Quote
Old 08-08-2009, 10:35 PM   #50
Diesel and petrol engines are different engine concepts.
Different combustion processes.
Old 09-08-2009, 08:10 AM   #51
hurhurhurhur's Avatar
new car mileage 3000k++ also can try?
__________________
signature????
hurhurhurhur is offline   Reply With Quote
Old 09-08-2009, 08:21 AM   #52
No rules stopping you, as long as your mileage is consistent, so that you can track the differences before and after adding the 2T.
Old 09-08-2009, 11:07 PM   #53
My friends added about 60ml of 2T oil to their Honda Civic FD, and 90ml to Honda Odessey. Will let me know the findings.
Friends did not note the mileage, but confirmed they top-up slightly lesser petrol at usual top-up distance/fuel guage mark.
Also commented smoother engine performance.
Old 12-08-2009, 02:56 PM   #54
AsusEpoxy's Avatar
what's the price of 2T oil?
__________________
[SIZE=1]Ghost3 Squad, move![/SIZE]
AsusEpoxy is offline   Reply With Quote
Old 12-08-2009, 08:09 PM   #55
Friend's Rush added 2T, noted FC up from 10.5km/L to 11.5km/L.
Old 12-08-2009, 08:10 PM   #56
I am using it now. it works!
What were the positive changes?
Old 12-08-2009, 08:12 PM   #57
Semi-synthetic 2T should cost about $12/litre or lesser.
A friend bought Mobil Extra 2T at a motorcycle shop in Jalan Kayu at $10.
Old 12-08-2009, 09:07 PM   #58
whitedragon's Avatar
Synthetic cant burn and will form hard deposits.... will if cause seal breakage in the pistons seals?
whitedragon is offline   Reply With Quote
Old 12-08-2009, 09:48 PM   #59
Synthetic oils are lubricants, altered such that their burning points (flashpoints) are higher than mineral oils, and providing better friction reduction between and/or around moving parts.
2T synthetic oils have lower flashpoints than 4T synthetic oils, and these 2 oils serve different purposes.
If both were exposed to the same high operating temperature, 2T oil will burn much more easily and readily than 4T oil.
2T oil must be pre-mixed with fuel to provide the lubricating effect in 2-stroke engines, whereas 4T oil circulates around the moving engine parts and circulate the heat away.
Old 13-08-2009, 03:37 PM   #60
flapdoodle's Avatar
For you folks on the 2T-in-fuel experiment, remember to check your spark plugs, monitor air-fuel ratio (it it runs lean its unhealthy) also keep tabs on the temperature of the engine.
I suggest you folks go easy as the excessive carbon build up and clogged catalytic convertors can be an expensive repair job.
__________________
[CENTER][COLOR=Silver][SIZE=1][FONT=Century Gothic]Please stop the mindless mindlessness. Copyright © 2005 - 2011, flapdoodle. All rights reserved. [/FONT][/SIZE][/COLOR]
[SIZE="1"][COLOR="Silver"]说你又不听,听你又不懂,懂你又不做,做你又做错,错你又不认,认你又不改,改了又不服,不服也不说[/COLOR][/SIZE][/CENTER]
flapdoodle is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
