www.hardwarezone.com.sg
www.hardwarezone.com.sg (/)
-   Console Gaming (https://forums.hardwarezone.com.sg/console-gaming-383/)
-   -   Help with PS4 Pro HDR settings. (https://forums.hardwarezone.com.sg/console-gaming-383/help-ps4-pro-hdr-settings-5534694.html)
aloy85 29-12-2016 10:15 AM
Hi guys,
I purchased a PS4 Pro recently, and hooked it up to my Samsung UHD tv (UA50HU7000).
While i am able to play my games at 4k resolution(3840x2160@60p), i am unable to play it in HDR as my UHD tv does not support HDCP 2.2.
Are there any devices which would allow my tv to bypass the HDCP 2.2 signal, and thereby being able to play in HDR?
Thanks in advance.
PierceLee 29-12-2016 10:52 AM
I don't have HDR tv but maybe you can try turning off HDCP on the PS4:
Settings > [System], clear the checkbox for [Enable HDCP].
wjwatchman 31-12-2016 12:42 PM
I have the same Samsung tv and the similar problem with the hdcp2.2 . I checked the user manual, and if I'm not wrong, only HDMI Port 3 has MHL which supports HDCP 2.2 but I haven't been able to activate the HDR yet. Need to tinker with it some more. Been trying to find an answer as well.
king81 31-12-2016 02:01 PM
Your TV model doesn't support HDR. Your only bet is to try and source for a Samsung Evolution kit 2015 but then again it was only released in the US and reported to have compatibility issues with local tvs as it was for the US markets. The enabled HDR capability is only for 2014 high end models such as HU9000, HU8700, and HU8550. So i am also not sure whether it adds that to your tv if you do get hold of the kit. Read up -http://www.flatpanelshd.com/news.php?subaction=showfull&id=1435569820 and http://forums.hardwarezone.com.sg/ho...s-5229260.html for more info.
wjwatchman 31-12-2016 02:33 PM
Thanks for the info king81. Quite bummed that my supposed 4K Tv can't fully utilize the ps4 pro capability. Hopefully there will be a firmware patch or something to help with this soon. Will go read up the link you sent.
shin7829 31-12-2016 05:04 PM
4k is 4k
4k with HDR is 4k Hdr ba
Only a 4k HDR. Can maximise ps4pro
wjwatchman 01-01-2017 08:48 PM
"4k is 4k
Only a 4k HDR. Can maximise ps4pro"
Yea I realized that now. Just gotta make do without HDR for now I guess. Could I ask everyone which then would be the best settings i should use for now?
Just go for the 3840 x 2160 - 60 Hz , color format RGB and HDCP 1.4 ?
shin7829 04-01-2017 07:56 PM
Quote:
Originally Posted by wjwatchman (Post 105563592)
"4k is 4k
Disable hdr in ps4 pro settings
Then choose highest resolution for your ps4 lor
They say it still will get refine better in. Terms of effects ma
But bro for the age of 30+++ and above our eyes cant really appreciate higher quality than full hd one liao .
Cause our eyes easily tired. Sometimes technology is a double edge thingy
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Copyright © SPH Magazines Pte Ltd. All rights reserved.
