www.hardwarezone.com.sg
www.hardwarezone.com.sg (/)
-   Digital Cameras & Photography (https://forums.hardwarezone.com.sg/digital-cameras-photography-12/)
-   -   Need help in adapter for my Nikon camera (https://forums.hardwarezone.com.sg/digital-cameras-photography-12/need-help-adapter-my-nikon-camera-6336917.html)
ly1968 14-07-2020 10:26 PM
Hi guys currently i hv a Panasonic Lumix G Vario 14-140mm lens (Micro Four Thirds System) but i want to use it on my Nikon DSLR D3100 camera,is there any adapter for it as i try searching on the internet but to no avail,tia :)
tjrsasea 15-07-2020 01:52 AM
Quote:
That's not possible. You cant adapt ur MTF lens to F mount (Nikon). What you can do is adapt F mount lenses to your panasonic body.
ly1968 15-07-2020 11:11 AM
Quote:
Oh no :eek:,anyway thks for ur info
RyanJosie 18-07-2020 09:12 AM
Dun think any makers will want to make such an adapter.
Micro43 lens has a shorter flange focusing distance, you cannot cross adapt onto dslr unless the manufacturer makes an optical adapter. And that is provided the lens does not have a very protruding rear recess. And with electronics now controlling focusing etc, end up needing a complicated electronic adapter. And the fact that the image circle of an M43 lens is smaller and might not cover the bigger D3100 sensor..
keenklee 18-07-2020 10:14 AM
Nikon DSLR are not really adaptable.
You will have more choices with Sony.
d3n 18-07-2020 04:25 PM
Canon also can
ly1968 19-07-2020 12:36 AM
Thks for info :)
ly1968 19-07-2020 12:39 AM
Oh ya i forgot i got another camera Sony A7II,does it have an adapter for this panasonic lens ?
keenklee 19-07-2020 01:46 PM
Quote:
https://www.google.com/search?q=A7II...hrome&ie=UTF-8
Looks like have.
ly1968 19-07-2020 06:37 PM
Quote:
Originally Posted by keenklee (Post 128569159)
Thks for info,cheers :)
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright © SPH Magazines Pte Ltd. All rights reserved.
