SBF Nov 2015
tiny
May sobf results should be out in Aug..
But then u would have gone for ur appt?
If got a CMI queue number for Nov 2015 SBF, and go apply for Feb 2016 BTO... ends up with another CMI queue number for Feb 2016 BTO, means I have used up 2 x first timer chance?
Gixxerfied
Considered use up only if they invite you for selection and you no show..
But also depends on the leftover unit, sometimes HDB at their discretion decides not to penalise you..
tiny
Let's say, I turn up for the unit selection but only left ground or 2nd floors.... it is not a No-Show. But really nothing to choose. Still considered use up 1 time? :eek:
Gixxerfied
That would be see HDB's mood..Usually they dont penalise for that but hard to say ba..
tingsters
i believe if you turn out for the unit selection, you can explain to cso who is attending to you. if he/she is agree then mostly you will not considered using the up the 1 time, better then they send you a warning letter for no show right?
walkofwinners
i don't think there is a warning letter for no show, balloted for sobf previously and my number was within the number of flats available. cso called me on the day of selection and asked if i was coming but i told her the choices not to my liking and she laughed it off and said better luck next time then!
duckie_15
Provided both cmi number call you up for selection and you reject both.
SecretAgent
Oh... We should be expecting a call on the phone if any should they want to get us to go over? Not an email or something? Because I am not in Singapore right now since last week result and I didn't put in my sg simcard in my phone!
Sent from ..... using GAGT
whereismyqno
Anyone here knows the actual selection period for Woodlands.
Though duckie_15 mention will be around June.
Need to plan before hand as hubby might need to go out sailing again :(
tinkerbot
If HDB indicate May is the month for flat selection for sales of balanced flat, when will they send the flat information ie: what units are available (although portal have) and its OCS usually?
I'm very excited to start researching on but lack of information from HDB.
bigeyesbabe
Same here. I wanna know does the SOBF comes with flooring etc.
