animeonegai
- Nov 27, 2003
RMN3 is more advanced than RM3 in terms of specs(eg. SD650 vs SD616, 16MP vs 13MP, 5.5" FHD vs 5.0" HD, fingerprint reader on RMN3 etc.).
Since you're already using RM2 now then RM3 should be similar. The RMN3 has the same screen size and resolution as your 6s Plus, but battery wise RM3 may be better due to them both having 4000mAh battery but RM3 only has a HD screen thus might be less taxing on the battery.
edit: Here's a battery test on RM3 by GSMArena~
Im torn between this and ulefone power.
