tigerwoods
- Oct 7, 2005
if sim tray spoil, about $20 for repair, excluding labour.My LG G3 cannot detect my sim card and can confirm it's not the sim card problem as i have tested on another spare phone and it works fine. Anyone have any idea if i go to service center repair, will they quote the repair costs before repair? My g3 warrenty have already expired.
any official response for the LG G3 battery issue?
i am damn dulan a brand new unused battery encountered the bootloop issue within 1 mth of usage.
so both of my batteries have died, and i refuse to spend $40 buy a new one. i shall go to LG service centre to kpkb.
anybody here tried to bang table there?
Damn, this 14 March thingy was crap.
Didnt waste time. Installed 30B MM Global LG G3 Rom, Rooted, Xposed, Tweaksboxed, Amplified, Greenified, Deodexed, Adaway, and now its buttery smooth. Just the way i like it.
Horray!
Can I find out from you if it's possible to fully unroot with no telltale signs that it was rooted before? I just took over this phone after using HTC so I'm not familiar.Damn, this 14 March thingy was crap.
Horray!
Sent from LGE LG-D855 using GAGT
Swee. Thanks, I shall do it when I find the timeyes. just flash original kdz file.
Seeing the battery issue and also the firmware glitch I'm experiencing, most likely this is my first and last LG phone. Had used 2 Samsung but didn't like the bloatware. Now I think bloat is still better than not working properly. Anyway will try something with stock (or close to stock) Android in the future seeing my cheapest tablet with almost stock Android can perform on par with this once a flagship phone.
I am experiencing boot loop. At first this happens when my battery is lower than 30%.
Then now this boot loop occurs all the time. And i have to continually charge it to just use the phone.
Im using the latest official version. Unrooted.
So is this a hardware (battery) problem or a firmware issue?
Looks to be a battery issue.
Does it run fine plugged in without batt?
yes. when it is plugged in, it is fine.
but i realise this boot loop nonsense only started to slowly surface after i updated the phone to the latest firmware version OTA.
