quite tempted by the S7 honestly, but seems like everyone is only rocking the edge version here, would you guys discourage me from S7?
I did the exact same setup for the S7 edge I gave to my gf.
Ringke with the $12 protector from mobile hardware.
Didn't post the photos I took cause it seemed too invisible. Haha
The edge will drives you to the edge
Wahaha
erm, drive me to the edge means drive me mad?
cos that's what it means literally..
so you would recommend the normal S7 bro?
hey guys, any idea where to get a tempered glass protector that covers the entire face of the s7?
I've seen burlington square being mentioned in the previous posts, but seems like there is OOS as well.
thanks!![]()
After pasting the SP, the auntie and I keep trying to take pics of my S7E to capture the effect but sibeh hard hahahaha
Sent from 10 Buangkok View, Buangkok Green Medical Park using GAGT
For S7 edgeless -- so far from my experience asking quite a number of shops wherever i go.. it seems like all tempered glass will not be able to fit the screen fully because the curve of S7 starts before the screen ends.
there might be shops who will try to sell tempered glass sp that will cover the screen, but you will get 2 glorious rows of halo by the side. and the sp will 'touch' the side of your front cam. some bros here suggested that it might an s6 sp.
so better play safe! and so far, there's no privacy tempered glass in the market (at least those i went to ask, and even samsung shop itself) even if have, i think it might be those 's6' sp.
i'm currently using cheapo film sp, while waiting for privacy sp. but i guess have to live with the fact that it wont cover the entire screen...![]()
