LG G3
aspeno
My LG G3 cannot detect my sim card and can confirm it's not the sim card problem as i have tested on another spare phone and it works fine. Anyone have any idea if i go to service center repair, will they quote the repair costs before repair? My g3 warrenty have already expired.
serverxeon
if sim tray spoil, about $20 for repair, excluding labour.
serverxeon
any official response for the LG G3 battery issue?
i am damn dulan a brand new unused battery encountered the bootloop issue within 1 mth of usage.
so both of my batteries have died, and i refuse to spend $40 buy a new one. i shall go to LG service centre to kpkb.
anybody here tried to bang table there?
Intrinion
Senior Moderator
Senior Moderator
I believe reading in an earlier post that the batteries sold by the service ctr does not come with warranty - so basically if it dies 1 month down the road, it is not covered.
However having said that, you can call them / head down to clarify :zotto:
PC-User
Seeing the battery issue and also the firmware glitch I'm experiencing, most likely this is my first and last LG phone. Had used 2 Samsung but didn't like the bloatware. Now I think bloat is still better than not working properly. Anyway will try something with stock (or close to stock) Android in the future seeing my cheapest tablet with almost stock Android can perform on par with this once a flagship phone.
animeonegai
everything else on this phone is great.
except
Battery life
Overheat issues
Battery reboot issue
Sunlight legibility.
kumar2004
Damn, this 14 March thingy was crap.
Didnt waste time. Installed 30B MM Global LG G3 Rom, Rooted, Xposed, Tweaksboxed, Amplified, Greenified, Deodexed, Adaway, and now its buttery smooth. Just the way i like it.
Horray!
funnycow
Horray!
hahaha :s13::s13:
finalforce
Horray!
Can I find out from you if it's possible to fully unroot with no telltale signs that it was rooted before? I just took over this phone after using HTC so I'm not familiar.
Sent from LGE LG-D855 using GAGT
hwsv07
I am experiencing boot loop. At first this happens when my battery is lower than 30%.
Then now this boot loop occurs all the time. And i have to continually charge it to just use the phone.
Im using the latest official version. Unrooted.
So is this a hardware (battery) problem or a firmware issue?
Intrinion
Senior Moderator
Senior Moderator
Nexus :)
Bloat on Touchwiz has dropped significantly too.
Intrinion
Senior Moderator
Senior Moderator
Looks to be a battery issue.
Does it run fine plugged in without batt?
hwsv07
yes. when it is plugged in, it is fine.
but i realise this boot loop nonsense only started to slowly surface after i updated the phone to the latest firmware version OTA.
kumar2004
