LG G Pro 2
mosh11
Hi all,
this is a fantastic forum , I have had the G Pro 2 for 2 years now , and I want to replace the battery because the performance is bad,
I live in Egypt , I want to buy the battery online , I've found a couple of batteries sold for 10$ on ebay , are they any good ?
please recommend me a good battery just like the original
progene
Hi all,
Hello there,
Can't comment much as I will buy the official product from LF Service Centre..
falcom2002
LG Egypt Customer Serice
Hi all,
Better get the original battery.
You can try the Customer Serice.
LG Egypt Customer Service:
http://allcustomercarenumbers.com/Customer-Service-Number-Lg-Egypt-04847
blue24
Hi Guys, just to check where i can get a LG G Pro 2 stand alone battery charger nowadays? a stand alone charger just to charge its battery.
anyone knows mind sharing, thanks.
algerr
Try your luck at Qoo10:
http://list.qoo10.sg/item/LG-ELECTRONICS-ORIGINAL-LG-V10-BATTERY-G4-BATTERY/417910380
Hope it helps.
Just to rant,
Sibei depressing nowadays.... LG G pro 2 is quite a good phone... but because this model's already out in market for quite some time... finding accessories(E.g Screen protector, battery charger etc) in shops is quite difficult... got to go online buy..=(
progene
Hope it helps.
Just to rant,
Agreed.. So always a good practice to buy accessories before before the phone become obsolete...
Sent from LGE LG-H961N using GAGT
stamina
Hi Guys, whats your latest lollipop version of G Pro2? Is it V20a,20b, 20c or ......? Any noticeable improvements?
kelvinti
Local set is 20b now.
More or less the same but technically it definitely improved even it is not noticeable.
No issue thou. 12b is running flawlessly since the update in October 2015 . :)
smeagoly
After more than 1.5 years with this great phone, it has started to show some signs of age (a little laggy and gave a blue screen of death twice) Was actually quite keen to jump onto v10 but it seems like the battery life is not very good.
Played with the huawei mate 8 and I really like it, maybe will consider switching to that if there are no news about g pro 3. (lg g5 doesnt interest me)
kelvinti
I did encounter a brown and a blue screen too last month, after 2 years.
So, I just performed a factory reset and the screen never came back anymore. Now, my Pro 2 is likes a brand new set again! :)
You can do that if you don't mind to set up everything again. :)
It is still a freaking high performance phone.
Hisashiburi
Still an excellent phone even though I'm using s7 now.
Would still be using G pro 2 if not for the camera. Camera just can't compare to s7.
Too bad we can't just switch the cameras...
kelvinti
I'm still waiting for a 5.9" or 6" new phone....
falcom2002
Huawei mate 8? The battery is a beast.
If only they put in a 4GB Ram along with the 4000mAH
battery.
Now, it is up to LG to think about such possibilities for
the upgrade to Pro 2.
It would be a killer if the next device flagship for their
Pro series has the following:
1. 820 SD as processor
2. 6" screen
3. 4GB or 5GB Ram
4. 4000mAH removable battery
5. MM 6.0 (making sure it would have no problem with
820 Superdragon processor
6. Phone need not to be slim but must be as rugged as V10
7. Camera and manual video control with bigger sensor size
than the V10.
8. 64GB internal storage with sd up to 1TB
Wow, will all these expectations be too much or too costly to
make the Pro 3 marketable. This is the question for LG and
its thinktank to crack. :s13:
OmegaSupreme
battery.
2. 6" screen
3. 4GB or 5GB Ram
than the V10.
:eek: Maybe you can try email to LG?:s13:
OmegaSupreme
Hi guys, got a question. i downloaded lg pc suite and it only support lollipop 5.0. As i'm currently still on kitkat,any older versions you guys are aware of still support kitkat version? Thanks.
