cheap and reliable mechanical keyboard?
ivanykx1
hi bros, i cant seem to pick what mech keyboard i should get.. any suggestions? i like blue switches and my budget <$200. the lower the better.. thanks :s22::s22::s13:
edit: sorry i forget i prefer having backlit too because i use my computer in the dark 90% of the time.
ragnarok95
Senior Moderator
Senior Moderator
Filco Mesjestouch 2.
Cheap and Reliable most time doesn't go hand in hand.
mnemo_05
im using a black hornet from armaggedon, pretty decent.. got it for arnd 115 i think
yusoffb01
Cheap and good? I switched from cherry to outemu switches. Less than SGD$70 can get led
Switch brands u can get is cherry, outemu, gateron, greetech
Switch brands to avoid: kailh
Ark Law
Filco. Very multifunctional - use it as a hammer, use it whack robber, use it to cripple a molester also can, and of course, can use to type.
yusoffb01
do the led at certain angle shine out from keys' bottom edge, the bright glow abit glaring?
i think i use my led kb for abt 45min, put back into box...
You can reduce brightness. Keycaps cover the led. The light reflects on the metal keyboard giving it a nice glow
hlots123
had reduced the brightness all the way down. in turn, the key lettering so dim until i prefer my non-led kb :s22:
is not a "nice glow" if u look at eg. the Esc key in ur pic... but mine is different kb
damienloh
Can some bro kindly advise the difference of keyboards beside the led? The split seconds of input? Tactile?
kicknikuku
Get this switchable one without the need for soldering.Team wolf.
Using it right now n happy with it. I also have ducky and pok3r but none as value as china keyboard lol.
yusoffb01
Get this switchable gateron one without the need for soldering.Team wolf.
I had cherry blue, cherry red, outemu blue, kailh brown... now I should try that gateron
