Air conditioning - Any recommendations please??
carlover76
how much it cost?
You mean the cost of the Controller for the 18K BTU Fancoil, I was told that it cost $160 for the controller whereas the rest of the Silver Envi fancoil do not need as it is built-in. =:p
Probably it will cost cheaper if get from other installer but have to check on the pricing again.
carlover76
To Terumo and other fellow air-con users,
are these kinda of air-con cleaners useful (see image below)?
Are they effective?
And most importantly, would it damage (eg: corrode) the fins?
User reviews most welcomed! Thanks!
I am using the one from Mckenic instead and I spray on the fancoil, let it penetrate into the fancoil then use the industry type of blower to blow through the coil, it will clear through the dirt onto the other side. It is cost saving in the long run and no waiting time to arrange for servicing schedule. =:p
amazingone
carlover76
ksrokiller
i see ok=)
empirestrike
The spray oni clean the surface only 15%... only chemical overhaul can do the cleaning job 99%...
empirestrike
Seems like the parts reliability for Fujitsu may not be true, probably I should try Daikin instead since they should be the expert in air conditioning. :s11:
u just see in the market do daikin made tv, fridge and other hardware.. no right? cause they just specialise in Air Cond only...:s12:
carlover76
Yes, you are right. This spray only used for general servicing and chemical overhaul cannot be done too frequent, probably once a year which they will dismantle the whole coil down to use chemical to wash the coil. =:p
CCCustom
Anyone knows what are the differences between Daikin Urusara and Envi, including price?
My piping is already done, meant for Starmex 2-tick, supposed to install the fan coils and compressor towards the end of my home's renovation works ... think I can still use this same piping if I decide to switch to Daikin Urusara or Envi? :o
carlover76
Oh, you mean you have confirm on Mitsubishi and piping done up without installing the fancoil and compressor unit? What piping, G23 and thickness of insulation used?
tanjhj
You can check from qoo10 also for price range. there is a aircon seller there, with the discount coupon plus cashback and credit card rebate is can be more cheaper if you are comfortable ordering online
Those are two ticks old model. they are clearing stocks not becoz they are cheap. selling at q0010 will cost them 10% commission.
i have checked with tim, aron and boon of renotalk their prices not that cheap also. u need to ensure the ticks before buying. coz with starmex 5 ticks system, the rest are clearing stocks on sale
tanjhj
hi all,
what is more cost effective (overall) get 1 system 1 for living room and 1 system 2 for rooms or get 1 system 3 2 x 9kbtu and 1 x 13 btu?
zeppelin
hi all,
For your living rm get a 1 system individual, better cooling. For Rms you can get the multi system.
ksrokiller
There is new model at qoo10 too i bought panasonic new 4 tick model system 2 with bracket from there.
Yingmushijiang
Hi guys. I recently got a system 4 Toshiba inverter Aircon from GC at quite a good price. I only paid the deposit and was told that I can still change my mind to another brand of Aircon if I want.
Does anyone have any feedback on Toshiba inverter Aircon? Is it reliable compared to Daikin or Mitsubishi? I got the one with 34k BTU compressor, 1 unit for living room and 3 units for the bedrooms.
Thanks!
cannotliao
Panasonic inverter system 3,
1 unit has blinking timer led.
I Checked error code H11.
Other rooms working nornally.
What can i do?
got the same H11 problem now.
anyone got repair before Panasonic aircon?
did you contact Panasonic for the repair or 3 party repair like Gain City?
anyone use Gain City for repair before? how the service and charges?
thanks.
precise
Thanks!
Me too. Thinking to change to tosihba. Can pm me the price you paid and what are inclusive. , like the material use and bracket.
Thanks
F3Rm1nat0r
any good recommendation for 24000 BTU single aircon for living room?
seems like not much offers on buying system 1 with such high power
Yingmushijiang
Thanks
Hi Precise, I got myself a Toshiba Sys 4 with the following:
1 x RAS4M26SACV~INVERTER
3 x RASM10SKCV~INVERTER
1 x RASM22SKCV~INVERTER
1 x stainless steel bracket
1/2" sys 4 (class 1)
Copper 22
Drainage pipe 16 mm
2 trips installation
Gain City $4569 (free gift of $200 Capitaland Vouchers) Got it during a sale at AMK showroom earlier in Feb.
Precise, why are you considering Toshiba Aircon? You heard any good reviews about it?
