galliano
- Sep 28, 2001
try e SALTS addon
Ya SALTS is the only reason I use Kodi now.
try e SALTS addon
finally got the box and tried myself...
ATV and WD My Cloud 6TB are wired to Time Capsule
Infuse connects via SMB
3TB Movie folder, Infuse takes about 7s to enter, acceptable.
Playback starts quite fast, spin around twice on 1080p files.
both ATV and NAS are warm only during the playback.
Anyone who has installed KODI, where did you all get your USB C cables from? Was thinking of getting one from carousell but scared quality chui
Same la. Can buy from sim lim square also. About $6-10. Seriously we only use it a few times so not a major concern
Haha thanks. Because I see online they talk about those cheap USB C cables frying devices, a bit scared. For such short use I think should be ok.
My AirPlay from MacBook Pro seems jerky. Anyone encounter the same thing?
mirroring? or in-app AirPlay? think AirPlay issues r mostly related to your local network...
Mirroring. Meaning to say there is some interference?
probably not enough bandwidth or e router can't handle e traffic...
how does kopi works? we have to manually install repos?thanks in advance
Any idea how to check? I am using viewqwest 1GB already so I guess shouldn't be a problem doing AirPlay
