1BadAssLobster
- May 28, 2012
your 2012 slow?
means something is wrong..
my 2012 is still working very fine...
Nope, many other users 2012 set don't age that well, all frustratingly slow.
your 2012 slow?
I just found out only this morning - auto-rotate does not work on my N7.
WiFi is not a problem though.
Upgraded to Android M more than a week ago.
Dear All,
Need help my nexus 7 (2013) stuck on google screen after ota update 5.0.2.
Can enter bootloader but can flash due to not root.
Cannot enter recovery to wipe factory reset.
Anyone can confirm need change motherboard.
Many thanks....
Hi, flash it require n7 to be unlocked state right?I have try NRT, same require unlocked set, it hang during trying to unlock.reflash using fastboot, fastboot doesn't need root.
if you want something easier to use, try WUGfresh's NRT
http://www.wugfresh.com/
Suddenly, there is no way for me to transfer files to my nexus 7 2013. Upon plugging in, can detect but cannot see the internal storage, tried different port and PC. I still managed to do so in Dec. From then till now never connect to PC, and only different is I updated it to latest firmware patch, Jan 2016 one...
I looked under the Settings > Storage USB > from there, I cant find any option to choose between MTP and PTP.
is it available locally ?? if yes , is it by ASUS ?
I did a system reset, after that finally found what you said... luckily it is just a secondary tablet for my child.With one of the recent updates, you need to enable the data storage on your device itself. When you plug it into the usb port, a notification should come up on your tablet. Click that and choose I think the 2nd option.
will there be a 2016 Nexus 7 from huawei?
my n7 2013 touchscreen jus die-ed. nw have to use through otg mouse to maneuver my tablet. sian a thousand halfanywhere to fixed it?
My N7 2013 touchscreen also drying, some part response to touch but most of them won't. Maybe it's not worth to replace since it is a 3 years old model.my n7 2013 touchscreen jus die-ed. nw have to use through otg mouse to maneuver my tablet. sian a thousand halfanywhere to fixed it?
i bought a new screen online and brought it to a shop and paid labour to install...total cost me around $100...still cheaper than what one stop shops charge
can pm me the online shop u bought the new screen. really like my n7 2013.
