Ink Tank System Printer
Kennedy
I am thinking of buying the Canon G2000. it's good or not ? or get other brands equivalent like Epson L210 ?
Thanks.
ericccc
ink tank printer ink pad very fast full, frequently use one year already full, then you have to change.
yusoffb01
Im using L210 since 2013. Print all notes in color almost every day using third party inks ($12 for 4 CYMK 100ml bottles). Never had ink pad full. Maybe he is confused
kandinsky
Actually, the more often you print, you should get less ink into the ink pad. Cos one of the main reasons for ink to get there is from printhead cleaning in between jobs.
The other reason is if you print a lot of borderless. If you don't print borderless much, this will reduce ink getting onto the ink pad also.
Kennedy
if low usage, will get bad clogging or not ? ink dry up ? the L210 can roughly print how many black pages with a full tank ?
leaning towards Canon because using their printers all along, familiarity preference. not sure whether to change brand or not ?
kandinsky
I can say the most modern inkjets unlikely to get clogging if you stick with genuine ink. I have two canons, on average print once a month, but sometimes can go 2-3 months without printing. Never had a clog in years, but I do use only genuine ink. The downside is that your ink is wasted on cleaning cycles to prevent clogging. Not sure if 3rd party ink will be just as effective in cleaning to prevent clogs.
yusoffb01
Canon quote 2000 pages. In practice around 1000 before need to topup. The longest i didnt print was 3months and no clog
If clog does happen, ink tank printers have ink flushing. Use 5% of your ink to remove clog. So its not a problem for dedicated printers.
U hear ppl say use third party inks get clog. Well i never used any original inks after it ran out, and still works fine. Could be because i use dye instead of pigment
If u only print black get laser.
kandinsky
This one I really not sure, cos long time nvr use 3rd party already. Good to know it works just as well.
jtjt00
I have the Epson L355, need to print weekly to prevent head clogging.
Kennedy
1000 pages ? Canon G2000 claims 6000 pages and Epson L210 claims 4000 pages. there's a big difference between advertising and practice.
kandinsky
Actually, manufacturers follow ISO standardized tests for getting print speed and page yield. I don't know if they are required to follow it, but I think most do it.
Page yield is usually quoted based on 5% page coverage per colour, most likely continuous printing one shot (no gaps in between so less ink used for cleaning, etc) so obviously YMMV depending on actual usage. If you're printing a lot of full pageimages, you can expect a lot lower yield since it differs from the test. It's useful for comparing products.
http://www.dell.com/learn/us/en/04/campaigns/dell-iso-page-yield
yusoffb01
Does it matter?
With $4 can buy 1 bottle print 1000 pages. If use normal cartridge need at least 10 x$22
Also cheaper than buying third party black toner
mnemo_05
I am using the Epson L220, got it for 199 at the last IT Show + 20 NTUC Voucher =)
a very decent printer IMO, I can print photos a A4 size without having to worry about the ink since they are dirt cheap.. print quality is very good too
coolnhappy
I sent my Epson l210 for repair only 4 months into the purchase and it's all because I seldom print. I would advise you to print regularly.
csc12345678
I have the epson l655, yea need to print regularly to prevent clogging
The printer head has warranty for 2 years, right ? Can change if clogged ?
The brochures say that it has duplex printing via ADF. Can I ask if it's possible to scan duplex to a PDF file to the PC, thumbdrive or memory card ?
Thanks.
JakeTeddy
erm does anyone know if the new Canon authentic ink bottles be used with other models of canon printer? Like other older Canon printer but modded with CISS / modded cartridges?
yusoffb01
Why not? Both needs to be same type (dye/pigment)
