Air conditioning - Any recommendations please??
carlover76
Guess I am confirmed with Daikin System 4 with the following configuration so checking on best quotations now.
Daikin System 4 (Mix)
Compressor : 4MKS80ESG
Silver Envi Fancoil (9K BTU) : FTKJ25NVMS x 3 (For 3 Rooms)
Normal Fancoil (18K BTU) : FTKS50FVM x 1 (For Living Room)
duracellb
To duracellb,
Living room can take 22/24k btu.
The unit that you use the most often can setup as a single system.
Or different rooms that you use often to one compressor, depending on your usage.
Hi Terumo, thank you so much for advising. Benefited a lot from your sharing in this thread.
precise
Me too looking at Daikin. Got a quote for 5k but with 24k btu for the hall.
Got a quote for mit 38va
1 New set (4 in 1 ) Mitsubishi Electric
MXY4A38VA (36,000BTU) +
MSYGE10VA x3 (9,000BTU) +
MSY24VA x 1
(24,000BTU)
$5035.
Do share with me if you have any quote for system 4.
teck13
The salesman told me he upgraded free insulation to Yamato insulation from Japan(white in color, different from black one and it comes in a bag of 45metre) and 23swg copper pipe. My hubby asked why the insulation so long and the salesman say it reduce condensation and then he also ask why it is not 22swg and he explained that they might tell u they use 22 but when they install time they will bring 23 or 24 one to cut cost which makes sense becos my hubby went to see my neighbour installation last week by some contractor so he kaypoh go and ask what pipe they using and they say 22 but then no packing one lei... only got marker write 22swg.. so hubby say better use reputable company for a/c, dun want to suffer leaking problem next time. Salesman was quite sincere and honest though.
The only thing good about them is they uses Yamato insulation from Japan.
Installers are from country B********h. 2 works on my installation. Claimed to hv 6-7 years exp. Squeezed 2 copper tubing to 1 insulation beco' they cannot go thru' the wall. Finished without vacuum the piping. Surprised to see whole group of them come to meet them when done...
Now master bedroom unit having plastic cracking sound. The shop, the agent and the factory do not want to admit there is a problem. Telling me to set to 24-25 deg with med-high fan speed.
copp3r
My MHI aircon broke recently after 7 years (installed in 2009).
Our service guy (Aircon Cooling) recommended a Mitsubishi Electric, while I'm undecided between these options, both are Inverter System 2 :
a) Mitsubishi Electric MXY-2E20VA / 2 X MSY-GE10VA for $2070 including installation.
This has 4 ticks (energy saving).
The service guy said this model is more quiet.
b) Mitsubishi Heavy Industries SCM45ZJ-S / SRK25ZJ-S x 2, same price as above.
This has 2 ticks.
The guy said this model has more issues with his past customers of not being cold enough, faulty spare parts, etc.
Any experience with these 2 systems? Does the ME system (2 ticks) really consume so much electricity?
Boeing101
MSY24VA x 1
(24,000BTU)
$5035.
Same system abt same price. I get from Coolserve.
unrealx262
if for two rooms , which models would yall recommend from either daikin or mitsubishi?
carlover76
I dun really like Mitsubishi starmex cos you can open the flap for cleaning but those are made of plastic so it will get loose after a period of time then will have some vibrating sound. That is my opinion.
Appled
Loosing sleep over this
I have no idea what Aircon is good. I know one thing for sure. The LG Artcool gave me nightmares. The blower thing got spoilt and took almost 3 months get new parts.
Now that i'm buying a resale unit, first thing i'm gonna do is to replace the old Aircon which look like from the 70's :eek:
Went to G*** C*** in IMM and was quoted as below. Don't know if this is a good price and if they are trustworthy.
System 3
Mitsubishi MXY-3G28VA 5 TICK
Indoor Unit - MSXY-FJ (2x9000 BTU + 1x12000 BTU)
S$ 3759
System 2
Indoor Unit - MSXY-FJ (1x12000 BTU + 1x18000 BTU)
S$ 3159
1/2 inch copper G22 - S$300
Extended warranty 1+4 years System 3 - S$129
Extended warranty 1+4 years System 2 - S$99
50Ft Piping FOC per fan coil. Excess us 4.50/ft for 9K/12K BTU and 7.50/ft for 18K+ BTU
Other Offer I received was as below:
Mitsubishi New Starmex system 2 - $3000
MXY3G28/MSXYFJ10/MSXYFJ18
Mitsubishi New Starmex system 3 - $3450
MXY3G28/MSXYFJ10 x 2 /MSXYFJ13
Standard piping materials without upgrade
1. 16mm pvc drainage pipe with 1/4 inch thickness armaflex insulation.
2. 23g copper pipe with 1/2 inch thickness Class “1” armaflex insulation.
3. Keystone/Sigma 3 core 40 & 70 wire.
4. Stainless steel bracket is additional $150 nett with installation if necessary.
Warranty
1. Compressor 5 year (Dealer warranty)
2. Other parts 1 year (Dealer warranty)
3. Workmanship 5 year (Installer warranty)
1st year to 5th year will be warranty piping and wiring but not included insulation sweating.
Insulation only warranty for 1st year.
April 2016 Package
** Free Site Survey
** Free 2 trip installation
** Free upgrade to G22 copper pipe (Thickness and Hardness gas piping)
** Free upgrade to Class “O” half inch Armaflex Insulation. (Fire protection quality)
** Free Unlimited piping length
** Free dismantle and disposal old set aircon
** One time ac-hoc general servicing with special rate for no units of install within 1 year- $15 per unit.
** One time ac-hoc chemical overhaul with special rate for no units of install within 2 year- 30% discount
per unit (Price different base on BTU)
** No hidden cost (Nett Price)
virtualape
maybe the electrical engineers here can help.
Not sure if its the compressor problem or a lack of gas.
my compressor continues running even though the fancoil is turned off. And it freezes up the external piping and the fancoil (the grey small fins behind the air filters become covered with ice).
only when i turn off the main, the compressor fan stops turning and the ice melts.
After defrosting, when i turn it on back, the air is cool and after about 30mins or so, it starts to freeze up.
possibly due to lack of gas that the compressor keeps turning or some electrical malfunction to the compressor?
tia!
carlover76
System 3
S$ 3759
System 2
S$ 3159
Warranty
April 2016 Package
** Free Site Survey
Wow, I did not know LG air-con is so problematic but I never trust any Korean brands or products even though it is popular or it claim to be very good or branded, I still trust Japanese products as they have pride in whatever they produce. =:p
precise
hI bros, any reviews to share abt best tech? considering a toshiba sys4...
thanks
Can pM me the quote you received from Toshiba Sys 4? Me too looking at it. So far, the quote I receive is $4149 (no upgrade of piping, inclusive of $200 Cap voucher and no bracket).
Deciding on whether Mit or Toshiba.
terumo
To virtualape,
Yours should be a non invertor system, maybe the magnetic contactor is faulty.
virtualape
To virtualape,
Thanks termumo. yes, its non inverter. probably better off changing the system. its rather old already.
CCCustom
Aron & Ah Boon's customer service is amazing.
I posted this not too long ago:
Anyone knows what are the differences between Daikin Urusara and Envi, including price?
My piping is already done, meant for Starmex 2-tick, supposed to install the fan coils and compressor towards the end of my home's renovation works ... think I can still use this same piping if I decide to switch to Daikin Urusara or Envi? :o
The above piping work was done by them.
And then I decided to ask Ah Boon on Whatsapp (because he doesn't answer the phone :s8: ) about the possibility of changing to either 5-tick Starmex or to Urusara or Envi, or whether I'm stuck with my original choice of 2-tick Starmex.
Msg sent early evening, he read the msg late evening, 2 blue ticks ... no reply.
Next afternoon sent another msg ... "do let me know pls, tks" ... he read it late evening, 2 blue ticks ... no reply.
Srsly? Business so good until don't even want to reply after reading? How to trust their after-sales service when they're already like that before the final sales concluded? :s8: I'm wondering if I should just pay them for the piping work already done and find someone else to do the fancoils.
KuKuBerg
hi bro, expo quote was at sgd40xx. what quote did u get? not sure whats the pros for toshiba other than made in japan...
cannotliao
my Panasonic inverter system 3 just uplorry, cost 2.8K in 2009 only 6+yrs spoil. i use it daily for 2 fcu, another fcu very very low usages, install for song.
the system never give any problem since day 1 then just sudden uplorry.
servicing said condenser/compressor pcb spoil replacement $600+
worth to take the risk repair? later other parts spoil again?
6+yrs can consider short lifespan? i was expecting it to last average 8~10yrs
CCCustom
As a follow-up to my previous post, Ah Boon replied this morning. Maybe news of this post got to them ... I won't know ... anyways he said he was on leave last week. I'll take it at face value.
Anyways, I am told that Urusara is single-split only, and Envi fancoils max at 14k BTU. Maybe this was already mentioned in here before but I didn't catch it ... but I guess that explains why some of you doing System 4 with Envi are using the old model fancoil for the living room, and this is something I don't accept.
I probably can't change my order from 2-tick Starmex to the 5-tick either, because my master and living room fancoil positions are cut-out from the false ceiling / L-box and the guys who'd installed the piping made markings meant for a 35-inch long cutout ... the 2-tick fancoils are 31-inches long and the 5-tick fancoils are 36-inches long. I'd probably have to go down to my unit with a measuring tape to see if they did the cut-outs according to the markings or whether they did a standard size cut-out, but chances are slim :(
I looked up the dimensions of several currently-popular brands' and models' fancoils and found that most are in the 9xx mm region in length. The 2-tick Starmex is pretty small at 798mm in length. If mine breaks down a few years from now and it is discontinued at that time and I need to buy a different brand / model, I think I'm royally F@%#ed :(
So ... lesson to be learned here ... anyone out there installing your fancoils into a cut-out in your false ceilings / L-boxes, do make sure your cut-outs are at least 1m in length or bigger for future replacement options.
