iV3RsOn
- Dec 16, 2003
Delivered via Singpost
MORRIS MOTLEY will be proud of ur pic....
hahahaha great photo editing skills u have there..
Like the difference between b cup and c cup.Wats the diff btwn mm balm n chrome?
Just bought Morris Motley and BB from Hairbroducts (gaoxing84's site), super accommodating dude with great business ethics.
If you're looking to buy hair products, support him thanks!
Sian part is Chrome just came and I just realized it...
thank you sir for your kind words
hi
for morris motley balm, is it very dry and hard to apply?
currently using dynamite clay and need to use alot of strength to dig out the clay.
how is it compared to dynamite?
thank you
hi
thank you
Its extremely creamy. Very easy to scoop out.
But applying on hair will be a bit rougher & 'damper' on the hair as compared to DC.
I initially hated it as I am used to DC smoothness but after some practice with MM, the trick to applying is to 'shuffle' it into the hair. It will quickly dry itself out during the styling process.
ermmm meaning it dry out quickly once on hair so it is tough to style?
sorry not very pro.
lastly will it be easy to wash off?
thank you
Where u get your bracelet?With Morris Motley Balm. 8 hours into the workday. Only applied a 20 cent coin amount into blow dried hair.
H&M's $3 discount rack 2 years ago.Where u get your bracelet?
Yours lasts so long ah? I bought from h&m before, lasted me only a few months...H&M's $3 discount rack 2 years ago.
