Nvidia Shield Gaming Tablet
Animagamer
thanks, I am still deciding whether should buy due to wifi issue then the misc bug that drain battery, but seems like only some have the issues. But staying at 5.11 lolipop is safe but would want to update the marshmallow
doki81
my K1 i think wifi is quite stable...on MM since open box then upgraded...
only down side is the battery is a bit less lasting than my mipad which on CM rom...now i am thinking whether to go DU rom on my K1 or not..
yeowenzheng
upgraded mine to 6.0..is that consider MM?
wifi i dont see much issue maybe because my MBR wifi connection is already quite bad even with iphones.
as for battery drain....on sleep mode for 1 whole day drain about 6-8% batteries is that ok?
doki81
mine on MM...if airplane mode...morning 7am is fully charged......left until 8pm...i check is 98% left.. 2% drain...
KlavierX
vainglory!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have my mipad to play VG as well...and now i order the shield from qoo10 but only found out they will only start shipping out on 29 Mar :(
you both play got non responsive ma? i tried playing one game ytd with the shield and do recording...
in the end keep dying because it doesnt respond to my touches when i thought it was
doki81
the recording will draw extra cpu processing and make cpu really hot...i think the normal game without recording already make the cpu quite hot...
so far mine dont have any touch issue...touch register seem better than mipad...
KlavierX
xie xie ni so maybe vainglory cant stream haha. my ringo feed for nth sia =[
KlavierX
sounds ok. marshmallow is android 6.0 so battery on sleep drain lesser
KlavierX
paiseh trouble you again when charging you play vainglory got problem? i stopped playing when charging. the touch not as responsive also
KlavierX
other than that i love the tablet and now getting the huawei mobile 4g broadband, singtel just sent my data sim (misplaced) to my office haha
GilaQila
Anyone has any problem with charging to full? It's taking ages for my tablet to get to full charge, especially the last 5%.
doki81
no such issue...which charger you using and is your charger output more than 1.5A?
