Xiaomi Redmi Note 3
garychengjw
Even Kasia Mobile selling at $325...Really waiting for dumb carrothead to chop...
i boycott them already.
trade lower then competitor, new set always higher/ex (i.e. apple).
think they earn from tourist since they located at suntec. :s13:
cowheadog
Can i ask abt the SIM card tray? By default it comes with the dual SIM card tray? Does it mean dat if i buy the other type (1 SIM card + 1 microSD card) i can jus switch them?
.笨 小 孩.
I can only say about the snapdragon version... There's only 1 type of tray only. The other slot is for you to put either 1...
gxelan
just got a message it is delivered to POPstation...will go collect it later !
hornbox
just to add 50dollar cart coupon start midnight daily, 5000 pcs, stack your mastercard $10 off, its just 2xx cheaper than xiaomi website
Which retailer? I will buy my Redmi note 3 x 3 sets for my family friends to use . I got mine at $299
cowheadog
Can any bro who got their set help? It says dual SIM and microSD card supported on mi website.
I borrowed my friend's Note 3 to try. He got it from China. I can't find any slots for microSD card?
Azure
Those who want redmi note 3 or urgent can get frm qoo10 got a shop selling local SG set too . Think it's quality at best value . After $50 coupon not bad price!! :s12::s12::s12:
cant use the coupon already the seller drop the price to $299
The qoo10 one cannot use the $50 coupon already.
I'm curious why they got sg stocks, also selling the same price.
Did xiaomi release to them before hand?
kewellz
The 2nd sim slot also works as SD card slot, so u can only choose either one to use..
