The Spectacles Thread. - Part 2
Karl_Jr
Anyone know whether spect in owndays good? Cos heard from 2 frenz asking me not to do spect there as spect did not so good. This has stop me from getting their graph belle spect which I m interested but need ppl to share buy for 2 piece at 50% price
Reasonably good especially the price is reasonable.
ymmak1987
Anyone tried purchasing lens from Richard Artelier located at Orchard Central? $148 for their ultra high index lenses (1.7 index). Seems like a prett decent price for replacement lenses for your favorite pair of frames.
osirisx
Saw a frame I liked at ownsday, but unfortunately they don't do transitions and PC lens combo.
Frame and normal lens 178
Top up 100 for either transitions or PC
How? Make the lens at another outlet?
My current photochromic spec was from new China optic at peninsula
Presto80
anyone know where can find alot of mykita and lindberg specs?
and is mykita or lindberg more expensive? do not want to be chop as some shops the price diff too much
snip82
Both are exp :s13: depend what your preferences and fitting. If not wrong, Mykita is also screwless but not sure if it using titanium but Lindberg is using titanium and acetate with Danish royal as it promoting background and win a few red dot prizes but usually their lens preference tied to zesis..
Presto80
yup. both are screwless. mykita is stainless steel.
dun see much mykita in shops and i always thoiight it is cheaper than lindberg
so now i want to check with other shop that carry mykita to confirm if this is the case or the person bluff me
ottica at shaw got quite a wide range of lindberg
thanx will go take a look.
TheCaffeEspresso
just went to China optical shop..one of the better price shop :)
uncle tony very friendly also.did chit chat with me abit :)
Sent from Mount Everest Base Camp using GAGT
Hidy Ho
Is that the exact name of the place? I couldn't find it on Google.
EDIT: I did some more research and I think you are talking about "New China Opticians" located 3 Coleman Street, #B1-12, Peninsula Shopping Centre. Can you confirm?
TheCaffeEspresso
yup is that shop at penisula. gonna make a new spec also? :s12:
Seannie
If spectacles keep slipping downwards when wearing after sometime, what to adjust?
Wearing thin metal frame that has plastic nosepads
best you can do is tell optician to narrow the distance between the nosepads, change to a silicone material for less slippage, and also adjust the temple end to hook down and hook in for more grasp at the back. If still fails, means the frame not designed well. Cant do much after that. Just keep pushing it back up yur face lo. :s12:
FireEmblem
just made a new pair in jb.
chose the crizal 1.67 eyezen lens. 980 rm for the lens. Got kenna chop carrot boh?
