Nvidia Shield Gaming Tablet
yeowenzheng
Anyone has any problem with charging to full? It's taking ages for my tablet to get to full charge, especially the last 5%.
then it might be ur cable issue?
i am using speedy 5 usb ports charge, no prob even when using 4 ports, 2 phones 2 tablet
i am using a micro usb cable meant for a china tablet :s13:
KlavierX
not really haha, i can play a few characters.
taka, ringo, krul, kestrel should be considered main. yes recorded thru the shield k1
KlavierX
so much easier to stutter step now haha last time on phone damn hard but now hp on the creep hard to see lol
doki81
..no roam character? :(
i use to play lane a lot......until...SEA player is all playing lane and i force to pickup roam :p
so now...other than my lane skaarf/adagio..i can also roam with ardan and fortress or adagio....and last is catherine...
jungle i only play fortress WP..
Animagamer
my K1 i think wifi is quite stable...on MM since open box then upgraded...
only down side is the battery is a bit less lasting than my mipad which on CM rom...now i am thinking whether to go DU rom on my K1 or not..
I see, that really clear some doubt about it. From usage how long does it last?
KlavierX
roam ardan haha i suck at phinn.
i tried some youtuber support saw before the catherine was like wtf LOL
doki81
doki81 how about you haha got do stream?
try once but i feel it dragging the extra battery from shield and didnt do anymore....
i have done it thru twitch previously..
also ask you...when you do jungle...you start killing minions from the center shop or from near base :p
KlavierX
walk till near shop ba since sometimes you walk until the near base ones they havent spawn
unless enemy team is fortress and koshka
fireantz
Updated but no time to test out as rushing to work... Haha
Sent from Huawei NEXUS 6P using GAGT
I've just updated. two main changes I see is the position of the button in landscape mode. 2 buttons on the most bottom left and one button on the most bottom right. pretty good for 2 hand use. Second, double press the power button to launch the camera function. not bad if u need to take a quick photo. another feature is the Android Doze, a marshmallow function, which (from my understanding) turn ur tablet to sleep when it is inactive. that gives a longer battery life I suppose. so far no issue encountered
