coyote
- Sep 20, 2000
Don't android already have the function, disable data while roaming and default is always that way
Sent from LGE LG-D855 using GAGT
That's a software switch that can be flip any time or flipped on accidentally whatever. You always want to check whether you accidentally enabled data while roaming.
The slot 2 is a hard switch that disabled data permanently. There is no worry at all.
