allanzzz
- Feb 16, 2003
Which firmware version are you on?
Hi guys, BEWARE... Yesterday I connected my G3 to my PC, open up lg pc suite & it show me an software upgrade is available. Thinking it was marshmallow upgrade I accepted yes. This is when the nightmare started, after upgrade completed my G3 got stuck in a bootloops. Only a hard reset (Power + volume down key combo) can restore the G3 to stock software. Wasted half a day upgrading software back to V21a-SEA thru OTA & reinstall all the apps. Don't understand why LG release a piece of CRAP program like the PC suite & a firmware which causes bootloops !!!!! Go to hell... LG
Yes but at a price unless you can talk your way through.
Sorry, I doubt you can talk thru any reason for cosmetic damage.
as in. will hv random reboot. random shutdown. cause i when i swap it using the original battery. seems to be fine now.
Sent from Samsung SM-G920I using GAGT
Most g3 phones are already out of warranty anyway so why stick to stock LG rom? Plenty of nice rom around xda, just root, install twrp and you are good to go. Test each rom until you are happy but I'd suggest you to at least try DU rom. There are plenty of ways to backup when rooted so you won't kpkb if u hv to redo and risk losing ur data.
Either ah beng or official lg to repair since its hardwareI need some help from the guru here.
I had a G3 which was previously flash to Cloudie 5.0 rom. Everything was fine and i subsequent flash it to Fulmic MM rom. It was working fine except for the GPS which constantly drop and refuse to grab the GPS signal.
Google and saw someone in XDA mentioning about opening the back cover and adjust the pin connecting to the 3 antenna on the back. GPS issue indeed was resolve but now my G3 cannot grab any mobile signal. Had change a few sim cards from SG m1 to MY Digi. Sometimes it would grab but after a while and drop. Phone will be in emergency call mode.
Can anyone advise what the next step of action? Thanks for reading.
PS: I had flash back to LG stock LL rom and currently on stock LG MM rom. But issue to persist.
