The Hair Thread - Part 4
gaoxing84
Bro saw ur web le. Hair spray nth much eh. Btw what is seasalt spray?
Sent from - using GAGT
i never sell hair spray ah cause i don't believe in hair spray anymore as long i learn my own technique to style my hair.
sea salt spray is to use on damp hair prior to blow drying for creating volume and shape of the style you want to do.
it's like a draft shape before you use wax/clay/pomade to style and finalise it.
Dingdingsong
Ohh liddat arh. Then how u style your hair to last it whole day sia share yi sia la. I morning 7 am style 12 my hair going rot alr leh(i use the original by blumaan).
And btw how to know if u apply enough hair product for ur hair to last the whole day. I scare use too much then too much weight then drop very fast. Then scare use too little then also drop very fast. Tips anyone?
gaoxing84
sea salt spray on damp hair, dry using hair dryer and use roll brush to create slight curls
then just use wax lor
learn, try many different amount. play with it.
it's supposed to be fun, not a one time thing.
Dingdingsong
Haha okay. Thanks alot.
whatme
You still in secondary school ah? I assumed your hair gotta be short?
Show picture of your hair leh
Sent from Sony E6853 using GAGT
Dingdingsong
btw if you would compare original and morris motley? how would you compare it? like what are the differences with these 2 product and how much is the difference?
sorry if my eng was bad but just want to know more about morris motley before buying it.
durant035
hi all have been looking for renati hair wax but not a lot of shops in sg carries the brand.
I read that most here go Chinatown buy their hair wax. where exactly ah?
Thanks in advance
