Nvidia Shield Gaming Tablet
symbiote28
anyone got this error? i transferred files and set it as a memory card (instead of making it an internal storage) and the file transfer seems slow. so i took it out and transfer it directly via my pc and slot the card again. it has a corrupted error and i had to reformat again. am i not allowed to transfer media not via usb to the shield?
yapcc
Hi there, I have the exact same problem as you! I realised that I needed to format the memory card again and use it together with the internal storage before I can transfer the files properly via USB cable. This works for me as my tablet is now recognised with 80GB storage in all (16GB + 64GB).
symbiote28
but this method for me works so slow. i'm transferring CBRs and videos that is about a couple of gigs and it's too slow :(
edit: did you notice any difference in transfer speed IF it is already part of the internal storage?
KlavierX
i think use as internal better, never tried normal method. what speed is your sd card?
KlavierX
Not yet. Will try this later. Thanks
I've got a question: the GeForce now, if i subscribe and the games that come with membership, do i need Internet to play them? Bottomline, can i play them on my travels?
Sent from Samsung SM-G935F using GAGT
never tried geforce now too many to play even before that but i suspect yes still need internet - i go read up and confirm
KlavierX
i believe so need
quote from website: http://www.tomsguide.com/us/geforce-now-game-streaming,review-3113.html
"It's worth noting that I was connected via Ethernet to a 40 Mbps connection and exceeded all recommended parameters for the GeForce Now service, and that The Witcher 3 was the only title that gave me any problems. I also used a router recommended by Nvidia for the GeForce Now Service: a Netgear W7000. However, I am not prepared to say that the problem was on the server side, as Nvidia did not believe that this was a common issue. If you choose to buy The Witcher 3 on GeForce Now, just be aware that it may not run as well as the service's other titles."
symbiote28
I think only 15mb write speed.
i believe so need
Yeah after reading alot more and understanding, basically it's a cloud service. Which means Internet always is needed.
xhera46
Anyone here not using the Shield world charger? Got any good/more affordable recommendations for non-nvidia one that can charge and play at the same time? (no negative charging):s12: :s12:
