ONEPlus ONE phone
matoonia
I have just upgraded system update 6.0.1 and now my watsapp is not working. Cyanogenmod os 13.0 and api dragon fruit 4. Can anyone help pls
Beta_Tester
I have some problems. After I come back from HK, upgraded The lastest firmware there. Seems like the Singtel network "gone". I arrived in Changi moments ago.
As usual on The phone and want to use as per normal. And I confirmed it is registered on Singtel network and also sim card no issue. I reset my network settings as well.
Now beside the reception signal tap on the,top right no H+ or 3G etc.
Anyone can help?
Thx
deckcard
Anyone can help?
Thx
Check if u hv enabled data? Enable if u hv not
Check your apn settings. If not set it
deckcard
Enabled..for sure. Let me get Home and check in apn settings
how do you know its enabled for sure? did you re-toggle the icon just to make sure? it depends on which ROM you are using, I believed the toggle is via quick settings, you just toggle the signal bar icon instead of a switch in the mobile network setting page. after which you should see 4G/LTE, HSPDA, 3G... blah blah beside that icon?
chiaph
Are we still able to purchase the OnePlus one device? Referring to brand new unit set
