Xiaomi Yi dashcam
ZhuTou!
Ya easy but u must know how/where to tap the power source
Can tap to the IU one
HeadQuarters
Is the IU power always running? Everytime cash card low value, the red light always lit up even when engine is turned off.
puzzled_06
Cool. I shall go use ez buy now. Hahaha anyone wants to group buy? We can split shipping
Sent from Sony E6853 using GAGT
ZhuTou!
Hearsay can tap to IU la but i never try before lol
Duno is it for parking mode purpose or ignition
I lazy one, just pay 30 bugs ask workshop do for me even tho i know how to pull the cable
Or u all play safe tap to ignition lor
Youtube got many beedio
RuOnline
Just get mine at q10. Self collect and the seller office. Best cam for the price. Cheap but comes with wifi function. Very clear video recorded in 4k. Nth much to complain le. Holder is not suction. Is double side for me.
Dragon
Administrator
Tap to IU is always on. If you require parking mode then tap to IU.
Hope this helps. :)
cscs3
IU takes very little power compared to dasdcam, which is nearly 1 Amp.
So if you run it even engine is off; You stand a chance to drain your main battery completely.
I see no point even you installed the large capacity SD card.
HeadQuarters
I also got mine at Qoo10 few days ago. $75 + $30 for 1 year warranty. Gray. English version. Collect at Digi-hub office.
Qoo10 got promo that period. Buy $160 get $30 discow. My charbo used her DBS Live Fresh card got another 10% rebate with $200 spent, so I bought more things :o
ZhuTou!
Can use double side tape?
Leave No Men Behind
Alternatively wan to save labour. Use black tape and secure for windscreen all the way to door then go through carpet etc. Black tape not so obvious. From angmo YouTube
EJB
Got from Digi-Hub also, video is wider than my old cam but my iPhone seems to have wifi issue. Downloading is not very stable.
RuOnline
Yea. The old type is suction cup. That new one the holder also use the same but instead of suction they replace with double side tape. That means they replace the transparent suction thing to double side tape.
RuOnline
Yea. I also collect from there. I dun have any wifi issue. Just that my iPhone 5c too old to view 4k video file. So can't dl any 4k file.
