extemporisation
- Jul 15, 2005
Hi,
I have a mid-2012 rMBP (I'll upgrade to a newer model in time), and these days I use it as my main computer. When at home, it's connected to a Dell S2340L and a mechanical keyboard.
The 256GB SSD is reaching its capacity, and I would like to have a DAS to store photos (mostly RAW files) and archive other documents that I've accumulated over the years.
What are my options for a DAS?
Should I:
(1) Buy a multi-bay DAS enclosure and my own hard disks; or
(2) Buy a packaged solution like the WD MyBook USB3?
Any recommendations for either one of the options? What are the pros and cons?
Currently, I backup my rMBP's SSD to a portable HDD via Time Machine. Is there a solution where the photos and documents in a single drive in the DAS are backed-up together with my Mac's internal SSD's contents into another drive in the DAS?
I don't have a pressing need for RAID; I am okay with periodic back-ups since it's already a habit.
Thanks in advance!
Should I:
Thanks in advance!
