LG G watch Urbane anyone?
daniel_83
I used the Moto360 since it was out actually. My screen was not always on because of batt drain and not lasting me a day.
On the Urbane 2 I suppose the 570mah batt is ok. But worried screen ghosting and burn in on POLED.
Yea I had the moto360 too
Hate it
Even the "always on" feature was half-f
My watch now at 94%
Sent from LGE LG-H961N using GAGT
x3dnd3x
You all got any recommendations for taking notes and when disconnected from phone, the notes still stay on your watch?
x3dnd3x
does your urbane still crash every now and then ?
Mine never crash.
Apparently last time my problem with the green blinking error i feel is because the watch face not compatible with the current Android Wear i had on phone.
Watch face meant for Android Wear 1.3 but mine on phone was 1.5.
cray
eting72
Easiest is to get a cheap prepaid with data
Sent from 少林寺 using GAGT
hi tohchr,
pardon me but still at a loss on how this work...just got the watch ytdy.
if a diff sim, does it mean when u answer or reply texts it will appear a diff no? what's the diff if the sim is a multi sim with the phone? have not really got time to fiddle wit it as wife wants to wear it cos it such a piece of work even without full functions :o
would really appreciate some tips. TIA.
tohchr
hi tohchr,
Under the "settings, cellular, advanced, watch shares same number as phone", highlight it if u are using another number. If using multi sim which have the same number as your main, then no need.
tohchr
After u paired with your phone, SMS and calls or even WhatsApp wechat messages will come thru the watch regardless of which sim is in your watch. It can push the messages thru network and not only Bluetooth.
eting72
thank you!
another question. the data and calls charges will be from the prepaid if u call and reply messages from phone?
x3dnd3x
Haven't got chance to really test out the cellular section, need to go get a prepaid card for it. Of course I can use the prepaid card my company gives me but its in my old phone which still uses normal sim.
eting72
If the watch is connected via Bluetooth to the phone, usage will be on the phone. If connected via network, then usage will be on the sim card in the watch.
thanks again.
what will be a good prepaid u would recommend? one that dosen't expire in a short time and needs topping up frequently....
x3dnd3x
thanks again.
Actually prepaid cards, you must always monitor. The only good thing is unused data can always be brought forward to the following month at a small fee of $1 or $2. Saves you quite abit.
If i'm not wrong, Singtel's prepaid only support 3G.
