Air conditioning - Any recommendations please??
carlover76
Can 4MKS80 use with Silver Envi system?
I thought 4MKS80FSG can only use together with those dull looking indoor unit. No?
No, 4MKS80FSG can be used with Silver Envi. Some companies quote me with this Compressor together with Silver Envi fancoil, normal fancoil and Silver Envi all are using R410 Gas so no problem.
diatomics
Hi guys, between the 3 companies i shortlisted
A)gain city
B)supreme air
C)star cool
I need really reliable and good services cause i seen many stories on bad installations and setup. Could anyone advise?
1YEGG2KOSONG
Hi guys, i'm looking to install a system 3 for my parents place, old HDB. Am looking at Panasonic and Mitsubishi. Couldn't decide on which. And also to get it from GC or other contractor. Understand that GC will be more expensive but there is extended warranty option. Contractor would be cheaper but workmanship probably would be better if I were to find the right contractor as GC will be up to luck on who is doing the installation. Hope you guys can shed some light.
Kippoer
Hi, need advice which type or brand aircon is suitable. 3 rooms and only switch on 2-3 hrs every night for 2 rooms when warm weather.
TIA.
noinimod
can advised which brand to buy i looking at mitsubishi and dakin system 4 ?
mitsubishi is more expensive. but it's quieter. not that daikin is that much noisier. they're both considered premium brands. can't go wrong with either
Pathfinder
popdod
High Honorary Member
If you want, I can recommend you the official installer for Daikin which they will do the installation if you walk in to the Daikin Proshop.
I will be getting mine from them around next month. =:p
Can sic contacts?
Thanks.
:o
meowkat
Where to buy daikin aircon?
i suggest you might like to visit the one
Fortuna Air-Conditioning & Electrical Pte Ltd
321 Alexander Road #03-31/32
Alexandra Central, Singapore 159971 ( beside Ikea)
Tel: 6710 7888
Fax: 6459 7728
Operating Hours:
Open daily from 11am - 9.30pm
including Public Holidays
i had visited the one at OneKM mall and Alexandra Central
I gave them the same specs i wanted..
Both Pro Shop.. but different pricing.
the One Km Mall more expensive of $300 and less explanation.
and i suspect the guy trying to fast sell, as the flyer says installation by 30Sep.. he said by 30 June have to install...
I will say bye bye to him.
On the other hand, the lady at Alexandra is very keen at explaining.
I give her one qn: "whats make the difference between n Misubitshi?"
her answer was:" Daikin only manufacture Air-Con"
judge and see it yourself.
I am goin to get the Alexander one next month before the buy date promo for the additional 2years spare parts ends.
