Xiaomi Redmi 3
artemov
I recommend Explorer. It's a decent file explorer, ad free.
Oh I just found out Explorer is included in the bloatware lol.
Didn't manage to get Google Play store working. Have to manually install Whatsapp and a few essential apps ...
MIUI is now 7.3.1. Wonder if 8 is coming out soon ...
Battery life is amazing. The Chinese bloatware and ads are damn irritating ...
mokseng
I think u got the unofficial version of MIUI. It comes with extra bloatware. The latest china version is 7.2.7.0.
I was referring to the app in playstore called Explorer. They are the makers of Root Explorer. Lol.
For installing playstore and google services/framework, follow this video.
Sent from Xiaomi REDMI 3 using GAGT
arigatoast
hi guys . where did u get redmi 3 transparent phone casing? those transparent ones will get yellow thru time...
lingua101
Dunno if it will even be released in sg.....just get the export set from qoo10 or lazada
Redmi 3 processor is sd616 with 2gb ram. Rmn3 is sd650, 3gb ram(pro version). Redmi 3 display is 720p while note is 1080p. Redmi 3 is 5 inch screen, note is 5.5 inch. Battery size both ard the same but redmi 3 last longer due to screen resolution and size. Note has slightly better camera. Note has fingerprint sensor while redmi 3 does not.
There's redmi 3 pro version out now for export set. It has an extra fingerprint sensor, 3gb ram and 32gb storage.
Does both SIM card on redmi3 support lte and what size? Quite disappointed that Redmi note 3 only 1 SIM card support lte and they are not in the same size :(. I need to keep changing the cards and troublesome as they are in the same size :(
lingua101
amazingone
Unknown Xiaomi Land spotted at GFXBench, with the latest Snapdragon 435 ..
Likely to be Redmi 3A~
Sent from my Rice phone using GAGT
Astro
Pull down the notifications list. Choose that "screenshot".. :)
Thanks guys. Need to scroll up notification then can see the `screenshot` icon. Anyway to make it appear on top? W/o scrolling up?
Is the fm radio loud in this phone?
Buying this for my half deaf father, always complain volume too low on his zenphone.
